dyno runs
This was exactly my view until recently. The PV has been out for about 1.5 yrs but was only updated with autotuning capability (online download) in Oct/Nov of last year. My view of tuning used to be as follows:
- Basic map from tuning library that matches your bike: 80-85% matched
- Smarttune from SEPST:85-90% (I used to tune alot with Smarttune)
- Dyno tune with competent tuner and many hrs on dyno: 90-95%
Such as roll-on going uphill or ramp entrance to highway or switching over to 2-up riding. After all the $ and time there would still be a hiccup or 2 that wasn't major but was definitely annoying after spending the $ and adding hundreds of miles to my odometer that wasn't with me in the saddle.
Now with the PV that simply doesn't happen. Its the difference between computerization and a talented tuner on a carb engine. Eventually the technology surpasses the human talent. You don't see guys tuning their mustangs on a dyno because the on-board computer plus O2 sensors in a closed loop system continuously does the optimizing.
HD's closed loop EFI systems are there yet but the aftermarket is pushing the technology higher. The SEPST Smarttune capabilities only let's you tune in the closed loop zone of the map (for EPA reasons) so you still need a dyno tune for the upper performance levels.
PV Autotuning has now moved owner-tuning capabilities to a new level. It tunes across the entire range of performance from 1000 rpms to your rev limiter and from 20kPa to 100kPa.
No other tuner has had that capability with the stock O2 sensors. The seat difference is dramatic for a whole lot less $ and the flexibility of updating your bike's map whenever an engine component or exhaust is changed.
I mean no disrespect to the reputable and talented dyno-tuners that are out there. They can still do wonders for a bike's engine but technology has caught up and for most engine applications, dynos will soon be obselete. If you have to have a dyno chart showing HP and Tq, then a dyno "RUN" is still the only way to go. But if "TUNING" is what you need, my view is the following:
- Basic map from reputable tuning library that matches your bike: 80-85% matched
- Smarttune from SEPST or TTS Mastertune:85-90%
- Powervision using Auto-tuning: 95-99%
I have no affiliation with DJ or anyone associated with the PV. I'm just a guy that's experienced ALOT of dyno-tuning and ALOT of Auto-tuning and the new PV Auto-tune gives bike owners real capabilities that match and I believe surpass the results from a generally more expensive dyno-tune. Just one one rider/tinkerer's opinion so take it for what you think it's worth.
The %s I shared are only based on one person's experience (me), so please feel free to discount them or use them as it best serves your needs. My purpose in sharing them is simply to be helpful to other riders that might be new (or not so new) to the latest tuning options in the market. Hopefully the views I've shared are taken in that spirit.
Throw your numbers at Doc and see what he has to say about that.
But there's so much more to a good tune than optimizing at WOT.
Think about it...almost every tuner-tech out there is tuning on a DynoJet Dyno. Aren't you at least a little bit curious about why the same company that builds and sells all the dynos that every shop uses has now developed a tuning device that the biker can use on their own to tune their bike without the need for a dynamometer???
My guess is that DJ knows the day of needing a dyno to tune an efi engine is quickly coming to an end and they wanted to be the first with the technology to use the bike's ECU, data collected from the biker's actual riding style and algorithyms in their PV that achieve the same optimization...consistently every time...not reliant on the skill of the tech.... in a small tidy package.... that no longer requires a dyno.
Read for yourself what the makers of the both the DYNOs in every shop use and the Powervision have to say. Get the facts, talk to reputable tuners and then make a decision for yourself. After much experience on both ends, its now an easy call for me http://www.dynojet.com/powervision/p...e-details.aspx (Click on Autotune - a product and a process)
