tuner what would u do
Old Feb 2, 2013 | 08:52 AM
lionsm13's Avatar
lionsm13
Thunder-Max would probably be "the best."
It certainly is the "most expensive."
I went with the PC-V from Fuel/Moto and it was pre-mapped for my stage 1 configuration. Plug and play, and super support from them.
Can't recommend them enough, as you'll see the longer that you are on this site.
Put different cams in the bike and then had it dyno-ed, and most dyno-ers can work with the PC-V.
Old Feb 2, 2013 | 09:09 AM
VTL nut's Avatar
VTL nut
Originally Posted by Catch My Train
Opinions are like noses, everybody has one.
You forgot:
"And most of em blow"
Old Feb 2, 2013 | 09:31 AM
Lowcountry Joe's Avatar
Lowcountry Joe
Oh no, the best is......
Old Feb 2, 2013 | 10:13 AM
bigdumbnoitall00's Avatar
bigdumbnoitall00
for a stg1 the best would be a waste of$.pcv or even fuelmoto micro tuner (if it works for the newer bike).maybe even ied:s.
Old Feb 2, 2013 | 10:45 AM
0ldhippie's Avatar
0ldhippie
The "best" is not an add-on device. I believe the PV is at the top of the Tmax/sepst/tts heap right now but the real key is a proper tune by a skilled tuner!
Old Feb 2, 2013 | 02:52 PM
12hdrk's Avatar
12hdrk
Originally Posted by papejr
Have a 012 ultra, replaced headers& slip on, now need air cleaner and tuner. What is best pcv or pv I dont see a need for future modifieds
"Best" is very subjective. Objectively, the PV is very easy to use and allows you to reflash the ecu with a very intuitive user interface or use your PC for even more flexibility. It also has an "auto tune" feature which will allow you to capture actual running parameters and modify the tune based on your exact riding style and conditions. Give Jamie at Fuel Moto a call. He will explain the PV and offer other options as well. I have the PV and it is a very cool device. Not cheap but usually you get what you pay for.
Old Feb 2, 2013 | 05:19 PM
Jswerve's Avatar
Jswerve
Originally Posted by Iceman24
I hit the keyboard and researched various options, read/studied/planned what I wanted from my bike and then just went for it. Asking for opinions/recommendations will only add to your confusion so just do some research, set a budget, think about what you want & do it.
www.dobeckperformance.com was my choice & works for my bike/riding/upgrades.
Old Feb 2, 2013 | 05:22 PM
smitty901's Avatar
smitty901
Power vision from dyno jet. cost effective easy to use does the job flawlessly.
If you buy it through Fuel Moto the tech support is great.
Old Feb 2, 2013 | 05:29 PM
cmashark's Avatar
cmashark
Power Vision is what I swear by. I have had the PC5, SERT, Vance and Hines Fuel Paks and the Power Vision. They all will do what you want, but the PV offers a lot of functions that none of the others do. My favorite is the fact that you can set it up tobe additional guages and you can data log with it. I have never been a fan of piggy back devices. Only you can decide, but I suggest you read up on each of them.
Old Feb 2, 2013 | 05:39 PM
Junkster's Avatar
Junkster
+1
Asking what is "Best" about anything on this site will just confuse you.
My Train & Ultra both have headers & high flow breathers, & I'm running
Vance & Hines FuelPaks. They are simple plug & play. No issues.
+2. If you ask for advice it just muddies the water. Do your homework and buy what you can afford for what you want to do.
