Fuel Moto compression?
Old Feb 9, 2013 | 12:03 PM
sg34's Avatar
sg34
Default Fuel Moto compression?
Hey guys ,
I just received my 107 kit and have a question for any of you that have done one.I didn't specify i wanted 10.5-1 instead of 10.25-1 did any of you? I know that they usually run 10.5 with the 777's just wondering if it's head gasket differences or piston differences? My pistons say 10-1.Thanks for any input.
Old Feb 9, 2013 | 12:22 PM
Puttnutt24's Avatar
Puttnutt24
subscribed
Old Feb 9, 2013 | 04:24 PM
sg34's Avatar
sg34
Really ,no one knows? I guess I'll call them on Monday not that it matters at this point,I'm not sending anything back after this long of a wait.
Old Feb 9, 2013 | 04:39 PM
tubeman426's Avatar
tubeman426
Originally Posted by sg34
Hey guys ,
Is the piston a flat top? if it is you would need to shave the heads a little to get 10.5-1 with a .030 head gasket. Did they do your heads? If so they may have taken some off to bring it up to 10.5-1.
Old Feb 9, 2013 | 05:15 PM
sg34's Avatar
sg34
Yea I had the heads done,I guess I'll have to check with them to be sure.
Old Feb 9, 2013 | 07:19 PM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
My FM TC107 kit with TW777's have these....
Pistons..
CP Pistons Harley (#cp bhm107-3)
Harley Twin Cam 107 cubic inch forged piston kit 3.937 in. bore size 10.75-1 comp.
CP Pistons brand Harley Twin Cam 107ci forged piston kit. For use in street; high performance and racing engines; for use with a 3.937 inch bore size and crankshaft stroke of 4.375 in. 10.75-1 compression. ( CP web site http://www.campbellenterprises.com/h...iston-kits.php )
Cometic Twin Cam 3.938 Head and Base Kit, MLS H/Gaskets #GSKC9902
Head Gasket HO872
R155S Silicone ORing base
Old Feb 9, 2013 | 09:59 PM
fidel's Avatar
fidel
when they say cam run with 10 to 1 comp its not the piston comp like wiseco 10.5 to 1 its static comp the result of the piston size and the combustion chamber of the head and the head gasket thickness go check the calculator on the link there really good coud vary a bit but close enough
http://www.bigboyzheadporting.com/TwinCamComp.htm
Old Feb 11, 2013 | 01:33 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Hey guys ,
If you are using our 107 kit with our standard flat top piston and our FM Level B CNC heads it will calculate to 10.4 compression.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old May 4, 2013 | 02:55 PM
BrianSF-GA's Avatar
BrianSF-GA
Pistons..
Head Gasket HO872
So Jamie, if we are running the CP BHM107-3's (10.75:1), +3 domed pistons with your kit 107" and your Level B CNC heads, what does the static compression ratio work out to be?
Old May 4, 2013 | 03:09 PM
grbrown's Avatar
grbrown
Wink
You really would be better off contacting him at his workshop, rather than on here!
