Little Help
Old Feb 21, 2013 | 01:23 PM
H B's Avatar
H B
Default Little Help
I bought an '07 Ultra 60 days ago. I have a very slight drip from the shift cable entry into tranny. 96 in 6 speed. Any suggestions?
Old Feb 21, 2013 | 01:25 PM
z71_fourwheelin's Avatar
z71_fourwheelin
If you mean the Clutch cable then there is an Oring that goes on the threaded part of the cable to keep fluid in the ramp area. Id replace that first.
Old Feb 21, 2013 | 01:39 PM
Jackie Paper's Avatar
Jackie Paper
Before you pull it for the o-ring. May sure transmission oil level is correct with bike level. Make sure primary is correct level to lower outer clutch disk and not to top edge of derby cover. (primary vents thru transmission) Be sure transmission vent hose is open. (little puff of air thru vent tube with transmission dip stick out) And most of all (and is what causes this a lot) is if you have an outer loose protective cover over clutch outer sealed seath that runs all the way up front, make sure it did not get a dose of oil that ran in it from the last filter change. Then it runs back from the air stream and appears to make it look like it is leaking a transmission. If it is actually at bottom of side plate below cable, it could be the two bolts for the side cover that attach the exhaust mounting plate are loose if you have that attachment.
Old Feb 21, 2013 | 10:29 PM
H B's Avatar
H B
Thanks!! I'll start my "investigation" as soon as it warms up a little. By the way RIPSAW did you learn all this at the Bates Motel?
fatboy slim
Dec 4, 2014 07:37 PM
diesel561
Oct 28, 2012 09:53 AM
lowdrag82
Jul 9, 2012 07:17 AM
cerelious
Apr 19, 2012 12:13 AM
deadite84
May 17, 2007 11:59 AM
