What is this line for?
Old Apr 18, 2012 | 08:58 PM
cerelious's Avatar
cerelious
Default What is this line for?
Hello all. This line is leaking on my ride, and I dont know what it is for or what type of fluid this is. Can I replace this line myself and is this a common issue? thanks for all the help and I need to get home to start riding my scoot with nice weather
Old Apr 18, 2012 | 09:51 PM
Crazy's Avatar
Crazy
That line is the clutch cable. It screws into the transmission outer cover, and transmission oil can go into the outer housing to lubricate the cable. Either the cable housing is cracked and fluid is leaking out that way, or it's leaking where the cable housing screws into the transmission cover.
As far as replacing the clutch cable, I don't know if you have the mechanical ability to do that or not. You need to loosen it at the adjuster, disconnect it at the clutch lever, and remove the outer transmission cover. You may need to remove you exhaust to remove the outer trans cover, depending on the bike and exhaust.
After removing the outer trans cover, you need some sturdy snap ring pliers to disconnect the end of the clutch cable at the transmission cover. The cable then unscrews from the cover.
Installation is the reverse, and be sure to put a new gasket on the transmission cover.
Do you have a service manual?
Good Luck
Crazy
Old Apr 18, 2012 | 10:07 PM
n0code's Avatar
n0code
That might also be your oil filter leaking, check that first and hopefully thats all thats wrong.
Old Apr 18, 2012 | 10:24 PM
a10182's Avatar
a10182
ya basically I wouldnt change any of that your self.......
Old Apr 18, 2012 | 10:41 PM
denimbob08's Avatar
denimbob08
you forgot to say eh
Old Apr 18, 2012 | 11:32 PM
Crazy's Avatar
Crazy
Good point.
Old Apr 18, 2012 | 11:41 PM
BoozerHi's Avatar
BoozerHi
"You need to loosen it at the adjuster, disconnect it at the clutch lever, and remove the outer transmission cover."
Check Oil and Tranny levels. If it's the tranny drain it before taking the cover off.
Old Apr 19, 2012 | 12:13 AM
Crazy's Avatar
Crazy
DOH!! Right you are. The kind of thing I'd do automatically, and don't even think about explaining.
Crazy
lowdrag82
Jul 9, 2012 07:17 AM
NOLAcustomFATBOY
Jul 18, 2011 07:26 AM
sundogbrew
Apr 15, 2011 10:33 AM
bbqbrisket
Apr 28, 2010 12:56 PM
HDF Tech
Jun 30, 2005 09:22 PM
