Clutch release cover cable and assembly
Old Apr 28, 2010 | 09:18 AM
bbqbrisket's Avatar
bbqbrisket
Default Clutch release cover cable and assembly
I'm changing all my screws on my 05 wide glide to stainless and I can see that I will need to unscrew the cable fitting from the cover in order to get to the screw behind the fitting.
What will happen if I just unscrew it?
Will fluid fall out?
Is the end hooked onto something in the cover that I might disconnect and then have the problem of putting it back together?
thanks
Old Apr 28, 2010 | 09:47 AM
jss1975snow's Avatar
jss1975snow
Yes if the bike is level it will spill, if it is on the jiffy it may lean enough not to spill, if you unscrew you should have a bit of residual but I don't forsee any major spillage. If you can change the stainless screw out from there that would best, if not the clutch cover can be removed and the cable ball end removed without disassembly of the rotating ball lever held together by internal snap ring. Be sure to place a new clutch cover gasket on.
Old Apr 28, 2010 | 12:20 PM
bbqbrisket's Avatar
bbqbrisket
Ok,
I will attempt to unscrew the connector on it and hopefully not much fluid will drip out.
thanks
Old Apr 28, 2010 | 12:56 PM
ghostrider69's Avatar
ghostrider69
I believe you will have to remove the cover to unscrew the cable. I removed all of my screws with the cable still attached when I switched to a chrome cover. Be careful because there is a o-ring on the fitting.
seanvanv
May 29, 2018 02:24 PM
jester3k
Oct 12, 2015 06:20 AM
cerelious
Apr 19, 2012 12:13 AM
C908
Aug 28, 2011 06:45 PM
gman116
Mar 27, 2011 09:44 PM
