Power commander question / help
Old Feb 21, 2013 | 11:29 PM
685power's Avatar
685power
Default Power commander question / help
Hello, need some suggestion and direction from those with PC III experience. I have an 2006 SG , 88 cu.in. , Roland sands air cleaner, MGS true dauls and Andrews 26 cams. Along with a PCIII. I can't get to a dyno tune before bike week because of a crazy schedule.
I tried a few maps that were kinda close tony set up and the 3-4 of them I tried , all had a problem either at idle, accelerating , or pops on decel. I finally put one in for a similar set up but for a 1550 cc motor. It's running beautiful. Pulls hard up the Rpm's, nice idle and no pop on decel.
I know this map isn't the optimum set up without a tune , but if all feels great, do you think I should be ok for bike week? Any input would greatly be appreciated. Thankyou.
Old Feb 22, 2013 | 04:57 AM
jus2anoyu's Avatar
jus2anoyu
Chances are, that map is gonna be richer than leaner for your setup. While richer is clearly the safer option, I still wouldn't want to ride thousands of miles with an incorrect tune If you're only talking about riding a couple of hundred miles, Maybe that will be OK. You know the pc3 has the ability to manual tune as Well. The buttons on the box will allow you to add or reduce fuel in the low, mid, and high range. Get a buddy to ride behind you. Ask him to pay attention to the exhaust of your bike when you are at different rpm. If he sees black smoke, ask him to note the speed and you can take away a little fuel. Again, richer is better, and it's your bike, your investment. Your choice....
Old Feb 22, 2013 | 05:00 AM
tbob's Avatar
tbob
Just FYI check your nozzle size that year they made the change .Did a deluxe that
had smaller size and the map set in the pc was wrong on mixture.
Old Feb 22, 2013 | 05:16 AM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
Ride it like you stole it....it'll be fine for bike week and beyond. If it runs good I wouldnt waste money on a tune.
Old Feb 23, 2013 | 12:34 AM
685power's Avatar
685power
thanks everyone. Tbob, good advice,but I checked when I bought the bike in 2010, and I have the upgraded injectors.
KEYBEAR
May 9, 2014 06:12 PM
klaybus
Apr 25, 2013 09:57 PM
tire_fryin89
Jun 13, 2011 09:42 AM
Lowside
Mar 8, 2010 04:14 PM
masterblaster
Jan 22, 2010 07:20 AM
