Dragon Fly Fairing USB Problems
Old Feb 22, 2013 | 11:39 AM
kanakattk's Avatar
kanakattk
Default Dragon Fly Fairing USB Problems
I have a Dragon Fly Fairing on my Road-King that i enjoy. My problem is, when i us it in usb mode i will get about a 40 seconds of music and then stops. all the other mode's work great. Does anybody else have any issues like this? and do you correct it.
Old Feb 22, 2013 | 01:36 PM
UltraNutZ's Avatar
UltraNutZ
have you contacted dragonfly? he hangs out over in the audio section quite a bit...
Old Feb 22, 2013 | 01:42 PM
Meist21's Avatar
Meist21
I had the same fairing with my RKC that I traded in late last year. I did have a similiar issue. I pulled the fairing off since it is easy enough to do, and noticed the connection for usb cord was loose. That being said I had the newer Medallion radio and not the Kenwood radio. I know the Kenwood has the usb port built right into it. I never cared for that design as I was worried that the vibration would damage the usb port. If you have the silver radio that gives you the ability to run a cord back to your saddle bag then check the connection right up behind the radio at the bottom of the fairing.
Old Feb 26, 2013 | 11:04 AM
kanakattk's Avatar
kanakattk
Thanks Meist21,
But i am running with the Medallion radio. I've tried calling Medallion, but it seem they dont like to return calls.
Old Feb 26, 2013 | 11:22 AM
UltraNutZ's Avatar
UltraNutZ
kanakattk, I think what meist21 was asking you to look at was on the back of your medallion radio, there is a USB plug. He stated that his was loose.
When you pull it apart to look, I would take a pair of pliers and squeeze together the top and bottom metal frame of the connection on the USB cable that plugs into the device. This will make it fit nice and tight.
Old Mar 6, 2013 | 10:50 AM
kanakattk's Avatar
kanakattk
I've found out that it was the usb drive its self. i tried three types of drives and the SanDisk drive works the best with no problems. and thank you UltraNutz and Meist21.
kickstartfan
Mar 26, 2019 03:13 PM
Nightking
Dec 19, 2009 06:32 PM
ojet
Mar 7, 2009 07:54 AM
07flicks
Sep 11, 2008 04:23 PM
Lord Albany
May 30, 2008 09:41 PM
