SE 255 cam's
Do some checking around and then get back to us if you have any questions.
EX Open 34, Close 14, Lift .555, Duration 228
SE255s INT Open 06, Close 25, Lift .556, Duration 211
EX Open 48, Close 07, Lift .556, Duration 235
SE254E INT Open 01, Close 43, Lift .535, Duration 224
EX Open 50, Close 07, Lift .536, Duration 234
I have had both the SE255 and the TW222 (current). Both are designed for low end/mid range. The TW222 pulls much stronger than the SE255, with as flat a TQ curve, but unlike the SE255 that runs out of steam at about 4500, the TW222 continues its TQ for another 500 RPM or so. While I do not have dyno numbers, seat of the pants dyno tells me the TW222 makes better HP and TQ across the RPM range than either of the SE cams above, has no hot start issues and just plain runs better. It also has a much better sounding idle than the SE255 FWIW IMHO.
Buddy of mine has the identical set up as mine and when we both had the SE255s, he would always edge me out, albeit ever so slightly. Since the swap to TW222s, I have no problem putting distance between us from pretty much any speed, including 2 up. The TW222 made 6th gear way more useful with pretty much no need to downshift in the hills, even at 70 MPH. I don't have to tell you what one of his winter projects was.
There are plenty of cam choices out there, many that make better HP at higher RPMs. You need to determined what your riding style is, cruising at 3K, or light to light 6K shifts. Once you know that, give Jamie at FM a call and he will tell you what you need.
If you want a good all around cam AND KEEP YOUR WARRANTY (without 900 miles of red tape) go with the 259s. If you want monster torque get the 255s. If you want a hot rod cam get the 254s.
Its all on how you ride. I prolly should have gone with the 259s or 254s but I do appreciate all that low end when hitting the hills.
