Oil pressure up 15 psi?!??!
Old Mar 7, 2013 | 07:34 AM
Varooom's Avatar
Varooom
Default Oil pressure up 15 psi?!??!
I have an 08 Roadglide with the FM 107 kit. The bike has 30,000 total miles with the 107 at about 5000.
Recently my oil pressure went up about 15psi. Ideling hot it would normaly be about 10, its showing about 25. Riding around 2500rpm when warm it would normaly be about 35psi, now its 50+. When I fire it up cold it is at 60psi!!!
The cam plate, oil pump, etc are all stock.
I am not getting any wierd noises and the bike is running great.
This week I changed the oil, filter and took off the oil cooler to blow it out and change the lines. I also checked the wiring behind the fairing. No change in oil pressure.
I guess the next step is to put a analoge mechanical gadge on the motor to see if it really is that high or is my oil pressure gadge flakly (I have Dakota Digital gadges).
I have been concerned with the stock flywheel/rod assembly as the FM 107 makes good power.
But if it was crank runout too high I would think I would notice other problems like noise and other horrable things.
I will put a mechanical gadge on it this weekend but was wondering what besides a clog, would cause oil pressure to go up so much?
Any input would be greatly appreciated.
Thanks for your time,
Doug
Old Mar 7, 2013 | 07:50 AM
soft 02's Avatar
soft 02
Dont want to scare you so ill just subscribe and see where this goes.
Old Mar 7, 2013 | 08:59 AM
jmorganroadglide's Avatar
jmorganroadglide
Big Kahuna HDF Member
Soft02 did an excellent job of not scaring the OP. I will follow also as it will be informative when the cause is found.
Old Mar 7, 2013 | 09:58 AM
Bowhunter61's Avatar
Bowhunter61
subscribed....doing a FM 107 build now
Old Mar 7, 2013 | 10:25 AM
icebite1's Avatar
icebite1
If gauge check out OK it could be the pressure bypass spring/check valve on the oil pump is bad or plugged.
The wife has the 107" also on her TG , 14k+ miles with no problems, its just what tubby needed to get it going.
Old Mar 7, 2013 | 10:33 AM
senna's Avatar
senna
I would think "icebite1" is on the right track. Maybe the cam chain tension-er is on its way out. Probably going to have to open the cam chest. That is assuming the mechanical gauge backs up the factory gauge.
Old Mar 7, 2013 | 11:08 AM
Def Mute's Avatar
Def Mute
Deleted...
Old Mar 7, 2013 | 12:39 PM
Lancemchn's Avatar
Lancemchn
In the middle of my FM107 kit now and began the process due to LOW oil pressure. You know, told the wife I had low oil pressure and needed to check out the plunger. Which meant new cam plate. Which meant new cams. Which meant new jugs and pistons, cuz there's NO WAY to get those pushrods out without taking the top end off. You get the drift... LOL. Turned out my crank had .020 runout so that had to be replaced also. Then... might as well upgrade the comp and clutch, it's all apart anyway. Oh yeah, and head work too. Only about $3500 into it now. Haha!
Hope it's just your gauge and not a real problem. My first thought is that your bypass valve is stuck. That would be a somewhat easy check. Then again, for me it would turn into a Baisley, then cams, then cam plate, etc, etc, etc.
Old Mar 7, 2013 | 12:41 PM
soft 02's Avatar
soft 02
You need help sir. Addictions suck. First step is admitting you have a problem.
Hi my names Soft and I am a poweraholic....
Old Mar 7, 2013 | 12:47 PM
Lancemchn's Avatar
Lancemchn
I hope these new mods satisfy that addiction. Does anyone know where the next PA meeting is??? Sorry to hijack, couldn't resist. :-)
