Penetrating oils, interesting read
Even if you're not mechanically inclined, this might be worth noting.
"Machinist's Workshop" recently published information on various penetrating oils. The magazine reports they tested these products for "break out "torque" on rusted nuts and bolts. A test was made of popular penetrating oils, with the unit of merit being the torque required to remove the nut from a "scientifically rusted" bolt.
Average torque load to loosen nut:
No Oil used ........................516 foot pounds
WD-40 ..................... ........238 foot pounds
PB Blaster .........................214 foot pounds
Liquid Wrench ......................127 foot pounds
Kano Kroil .........................106 foot pounds
ATF/Acetone mix...................... 53 foot pounds
The ATF/Acetone mix is a "home brew" mix of 50/50 automatic transmission fluid and acetone. Note this "home brew" released bolts better than any commercial product in this one particular test.
Our local machinist group mixed up a batch, and we all now use it with equally good results. Note also that Liquid Wrench is almost as good as Kroil for 20% of the price.
ATF/Acetone mix is best, but you can also use ATF and lacquer thinner in a 50/50 mix. ATF = Any type of Automatic Transmission Fluid.
This version of the story was in one of the Military Vehicle Club newsletters.
Scientists use it to machine delicate stainless steel parts and threads.
For aluminum alloys it allows deep drilling without need of deburring.
