Torque wrench question
Old Mar 14, 2013 | 09:00 AM
Lemayco's Avatar
Lemayco
Default Torque wrench question
If I put an adapter on my 1/4" drive torque wrench so I can use my 3/8" drive sockets will the torque value still be accurate. Thanks
Old Mar 14, 2013 | 09:02 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
The twisting force stays the same.
Old Mar 14, 2013 | 09:20 AM
senna's Avatar
senna
^ correct, it when you use an offset adapter (such as a crows foot) that you will have to adjust the torque value.
Old Mar 14, 2013 | 09:31 AM
Duke 07's Avatar
Duke 07
Yes. The only time adapters will change the tq is as stated with a crows foot, or what we call a "dog bone" adapter, and you can use those if you place them at a 90 degree angle. The key is to not lengthen or shorten the tool with the adapter. A simple 1/4 to 3/8 adapter keeps the socket exactly where it is supposed to be.
Old Mar 14, 2013 | 09:34 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
It will be close enough, don't sweat it.
Old Mar 14, 2013 | 11:55 AM
trnewman's Avatar
trnewman
What about using a long ball hex extension? I used one on my clutch cover so I didn't have to take off the exhaust but I wasn't sure if the torque would remain the same.....
Old Mar 14, 2013 | 12:28 PM
0ldhippie's Avatar
0ldhippie
As long as ya stay on the center line (Swivel/universal joint/sockets are fine) of the torque wrench it doesn't matter what ya plug onto it. Crows foot won't be accurate.
Old Mar 14, 2013 | 02:55 PM
foxtrapper's Avatar
foxtrapper
Torque stays the same. It's like using u-joints on a driveshaft.
Little loss perhaps due to friction if you're at a good bit of an angle.
Old Mar 14, 2013 | 09:23 PM
rjg883c's Avatar
rjg883c
Crows foot? Dog Bone? Are those the same thing I was raised to call a "wobbly"? Actually I think the technical name is 'universal'.
Old Mar 14, 2013 | 09:27 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
all three different, you're good
