another fluids question
Old Mar 14, 2013 | 01:54 PM
lumper's Avatar
lumper
Default another fluids question
Hi all,
This isnt a typical what should I use question, I need some technical data from the manual for quantities.
I just need to know the correct amounts for each hole.
the oil, tranny, and primary.
If you could look up or if you know off hand the quantities for an 07 Road King police with the 103", 6 speed I would be greatful
UPDATE:
Ok I found all I needed so I am going to update and share so if anyone else needs the info it is easily found.
for my 2007 road king police with a 103/6 spd
The 103 touring bikes like my Road king call for 3.5 to 4 quarts full, add 3.5 and check
The tranny gets 1 qt and check level, 6 speed anyway
the primary gets one Qt and check with derby cover off and bike level. either on a lift or a block, not the jiffy stand.
all three have seperate drain plugs that have rubber o rings to inspect and replace
the two filler caps and derby cover have a gasket and crushed washers or other o rings to inspect and replace if needed.
The drain plugs have a magnet to inspect and clean.
Thats all I needed.
Thanks and good luck if this helps anyone
Lump
Old Mar 14, 2013 | 07:59 PM
dawg's Avatar
dawg
Originally Posted by lumper
.........for my 2007 road king police with a 103/6 spd.......the primary gets one Qt (38 oz technically).......and crushed washers (o-rings, haven't seen crushed washers on them)
See red
Old Mar 15, 2013 | 07:22 AM
grbrown's Avatar
grbrown
Lump, that info is in your owners manual! If you don't have one you can download one off Harley's website. Just go to the 'Owners' tab. Same comment applies to all 06 and later owners.
beary
Jun 8, 2017 07:21 AM
Bryant91b
Jun 1, 2012 02:13 PM
2007ELECTRICGLIDE
Apr 30, 2011 08:24 AM
Javieret
Apr 4, 2011 06:59 AM
swiftlube
Nov 19, 2006 08:40 PM
