Bar Swap - What Am I Forgetting
Old Mar 14, 2013 | 02:14 PM
taygull's Avatar
taygull
Default Bar Swap - What Am I Forgetting
2012 RKC
Going from Heritage Bars to Carlini 16" Gangster Apes! Will start next Friday evening continuing over to Saturday and plan on having a "bar party" at the house with buddies and their wives to hang out eat some smoked BBQ, drink beer and act like idiots most of the day.
I'm not much of a wrencher but have been years ago, I did help swapping out the heritage bars from stock but that didn't include new cables, wires, etc...
So the bars will be here next week along with other goodies...what am I forgetting?
New Bushings
LA Chopper - Braided Cable kit /ABS
wire kit
TWB
Transmission Gasket
Transmission Fluid
Brake Fluid
Repair Manual
Solder
heat shrink
Good Friend
Smoked Pulled Pork and all the beer we can drink
I just have this weird feeling I'm forgetting something and don't want to have to make extra trips to the parts store or HD.
Old Mar 14, 2013 | 02:24 PM
C.H.L.'s Avatar
C.H.L.
The able kit have both Brakes and Clutch???
Looks like you got it all to me.
Old Mar 14, 2013 | 02:28 PM
taygull's Avatar
taygull
Yeah...well it is suppose to. I guess I'll find out when it comes in Monday or Tuesday!
Old Mar 14, 2013 | 03:46 PM
Gunnysgt's Avatar
Gunnysgt
I swapped out Heritage style bars for 14" Wild Ones last month. The only thing I didn't see on your list was a large helping of patience, When you are pulling those wires thru the bars and removing all the wires from the molex connectors etc, you will need a healthy dose of it. You may also want to add some words to your vocabulary that those around you may accept when things go wrong. It's not all that bad but will test ya.
Old Mar 14, 2013 | 05:09 PM
Grimace97's Avatar
Grimace97
If its internal wires get some wire lube.
Old Mar 14, 2013 | 05:13 PM
Jswerve's Avatar
Jswerve
I used industrial grade wire lube it evaporates after a short time. Bought it a Menards
Old Mar 14, 2013 | 05:33 PM
BenRK05's Avatar
BenRK05
I didn't see a top clamp on your list. Also a coat hanger or fishing line will help pull the though the bars.
Old Mar 14, 2013 | 05:41 PM
2ropes's Avatar
2ropes
Aren't there some copper or maybe they are brass washers needed for assembling the new brake lines to the cylinder?
Just trying to compile a list myself for a set of WO518's.
Old Mar 14, 2013 | 05:55 PM
Glockmeister's Avatar
Glockmeister
beer!
errr, installation fluid...
Old Mar 14, 2013 | 07:24 PM
Gunnysgt's Avatar
Gunnysgt
If you bought a brake line kit the crush washers should be in there. I have done several of these installs and have found that the Harley crush washers seem to work best. Don't ask me why, don't know, but the ones I did with aftermarket washers always were harder to stop pressure leaks. Silicone spray works plus take the large plastic wrap off the wires and use shrink tite instead. Dont' shrink it the whole way, it bends better.
