4 inch Basani mufflers
Old Mar 17, 2013 | 06:25 AM
Redneck 1's Avatar
Redneck 1
1st Gear
Default 4 inch Basani mufflers
I have a set of four inch bassani mufflers on my 12 Electra Glide Classic. The right side is hitting the axel bolt? I have tried to adjust the pipes and can not get the muffler far enough away from the axel? Any suggestions appreciated!
Old Mar 17, 2013 | 08:04 AM
BearHawg's Avatar
BearHawg
Can you post a few pictures?
Maybe if we can see it we could tell you where to adjust it.
Did you replace the headers also?
Old Mar 17, 2013 | 09:10 AM
Pumba11's Avatar
Pumba11
Have you loosened the muffler clamp and twisted it outwards away from the nut, as shown in my diagram?
Old Mar 17, 2013 | 09:57 AM
Zimbob's Avatar
Zimbob
I had the same problem with those on my '07 Road King. I used a grease pencil and marked the spot then removed them and Took a small mallet to that spot. Problem solved.
Old Mar 17, 2013 | 11:30 AM
DeneFXDWG's Avatar
DeneFXDWG
I put 4 flat washes as spacers under each of the bolts to drop it down slightly. Worked fine for my Fatshotz.
Old Mar 17, 2013 | 11:56 AM
mikelikesbikes's Avatar
mikelikesbikes
Sure would like to know how you made this???
I had Basani on my Road King but now have RC Excalibur. No problems here.
Old Mar 17, 2013 | 12:03 PM
rleggs's Avatar
rleggs
Ball peen hammer at the right spot will solve the problem.
Old Mar 18, 2013 | 02:44 PM
Pumba11's Avatar
Pumba11
Mike, I just made it up real quick on Microsoft Power Point. Then made a .jpg screen shot of the screen. Does that make sense.
Old Mar 19, 2013 | 11:08 AM
mikelikesbikes
Thanks and I'm sure it would if I knew how to use Power Point.
boready2
Oct 8, 2012 07:13 PM
inkmanjinx
Exhaust System Topics
Sep 16, 2010 08:17 PM
heinkel150
Oct 19, 2009 04:28 PM
marv122
Feb 14, 2008 04:22 PM
bobcowan
Oct 25, 2007 04:08 PM
