Tire Cupping?
Old Mar 18, 2013 | 08:02 AM
santajim's Avatar
santajim
I spent a life time as a brake and front end mech. and have seen every tire wear pattern there is and as a rule cupping comes from low air pressure, that being said the HD stock tires are **** to cupping and the only way to prevent it is to run them a little over inflated(3-5 lbs). I changed mine out to American Elite and love them, last year had a rear blow out near a dealer and have extended warranty with road hazard they put back on a HD tire and a few months ago the cupping started so I ran the air pressure up a few pounds and it has helped but the problem with this is once a wear pattern starts you almost always can't stop it.
Old Mar 18, 2013 | 10:02 AM
Biker John's Avatar
Biker John
Seen more cupping from Metzler tires...Twice.
Changed over to Dunlop E3 and like them, nice strong side wall and truly made for a heavy bike(s) yet rides just fine.
Old Mar 18, 2013 | 11:11 AM
Jerry1834's Avatar
Jerry1834
I have tired the running with hight psi and it didn't do a thing to prevent cupping (new tires). Dunlop had me doing field test on them with weekly reports. Can't say any more on the that subject.
Now, it could have to do with the type of road we have in Florida but the others I have heard from around the USA....They just cup!
Old Mar 18, 2013 | 11:19 AM
2black1s's Avatar
2black1s
Originally Posted by grbrown
That has worn in an odd way, but looks like not enough pressure to me. I suggest you use a few more psi in your new tyre.
If 40-42 psi is under-inflated for a 190 lb. solo rider then you might be right.
Old Mar 18, 2013 | 12:14 PM
HazyHog's Avatar
HazyHog
Right, not just in Florida. My rear stock Dunlop is cupping and I have always added a couple of extra pounds of air.
Old Mar 26, 2013 | 02:48 PM
zeus33's Avatar
zeus33
Big Kahuna HDF Member
From what I've read on the subject it could be caused by low tire pressure. But it can also be caused by normal wear depending on how you ride. If you spend a lot of time in corners, and are riding hard you'll put wear on the sides of the tires where they meet the ground. The cupping is normal wear.
Different tires wear differently depending on the riding style.
I'm still trying to figure it out, you'd think someone like an engineer would have it all figured out and could post the final answer.
Old Mar 30, 2013 | 08:01 PM
berniemc's Avatar
berniemc
Ran 45 lbs in my current set of Dunlops and rear is dipping bad at 10000 miles.
checkers
Wheels/Tires
Sep 13, 2016 07:28 PM
sn95bullitt
Wheels/Tires
Dec 2, 2015 07:23 AM
DaveMK
Jun 9, 2013 09:06 AM
journeyman
Jul 12, 2012 08:06 PM
Snowyone
Feb 27, 2012 10:10 PM
