Chasing down an oil leak
Old Mar 18, 2013 | 04:46 PM
stro1965's Avatar
stro1965
Default Chasing down an oil leak
Been seeing where my bike is marking her territory lately. Started looking around and found the problem (I hope). The 2 bolts that hold the exhaust bracket to the transmission were less than finger tight. It's a bitch trying to get an allen wrench in there without pulling the exhaust but I was able to snug them up. Exhaust is coming off soon to do cams anyway.
Old Mar 18, 2013 | 04:49 PM
DPete's Avatar
DPete
Hex head bolts and lockwashers then you can get a 1/4" drive wobble socket on them.
Old Mar 18, 2013 | 07:27 PM
stro1965's Avatar
stro1965
I may very well do that when I pull the exhaust!
Old Mar 19, 2013 | 07:24 AM
grbrown's Avatar
grbrown
Cool
You are a spoil sport! She was just starting to enjoy herself.....
Old Mar 19, 2013 | 07:32 AM
stro1965's Avatar
stro1965
Probably her way of telling me she feels neglected over the winter.
Old Mar 19, 2013 | 08:37 AM
Lowcountry Joe's Avatar
Lowcountry Joe
These two bolts have caused leaks on numerous bikes.
This same thing happened to my 2010 when it had about 2000 on the odo. Guess it took that long for them to vibrate loose. I did what you did....used the ball end of an Allen to snug them up on a temporary basis. That stopped the seepage and I kept an eye on them until I changed headers. When I had the header off, I replaced those two bolts with some grade 8 Allen head bolts with lock washers. You can't see these bolts anyway, so get some good solid bolts for this application.
Also, I believe the torque spec has changed on those bolts from where it originally was in my service manual. From memory, I believe the original torque spec was 14 ft lbs, but I read somewhere on here, maybe it was a Dawg post, that indicated the torque spec had been increased up to 22-24 ft lbs. I torqued mine to the 14 ft lbs with the new bolts and lock washers and loctite, and have experienced no problem with them since.
Old Mar 19, 2013 | 08:52 AM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
I tried to deal with the root of the problem= Exhaust vibrations against Engine vibrations
I removed the carriage bolt then slackened the two 1/4" Allen screws to have a gap between the two galvanized support plates (fixed by the carriage bolt).
I put copper grease between the two plates then re-assembled everything without over-tightening the carriage bolt to give the greased joint a bit of freedom.
brad75raiders
EVO
May 26, 2018 01:06 AM
ronherman
Sep 3, 2013 07:31 PM
firefightermike
Sep 25, 2011 09:49 PM
matt_wahoo
Jul 29, 2011 09:22 AM
otter8
Mar 29, 2011 06:09 PM
