Push rod lengths are different?
Old Mar 18, 2013 | 09:13 PM
Snowmaster113's Avatar
Snowmaster113
Default Push rod lengths are different?
Hello doing a cam swap on my dads 06 Electra guide and I got a bit ahead of myself and pulled the stock push rods out and forgot to mark them. I did keep the 2 from the front and the 2 from the rear cyl. Separate. But as I was going over everything tonight I noticed the push rods are different lengths and not sure which ones go where. Any input would be appreciated... Thanks in advance.
Old Mar 18, 2013 | 09:23 PM
DTTJGlide's Avatar
DTTJGlide
It tells you in the service manual, & you shouldn't be doing that kind of job without one!
Old Mar 18, 2013 | 09:29 PM
Snowmaster113
I do have a service manual maybe I should have checked there first. Thanks
Old Mar 18, 2013 | 09:35 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Intake stock pushrod is silver and the exhaust side pushrod is black. Good luck with the install. I hope the base circle of the cams you are using is exactly the same height as the base circle of the stock cams. Adjustable push rods make life easier and allow for more adjustment...and a hell of a lot less install time.
Old Mar 18, 2013 | 11:55 PM
heavyd460's Avatar
heavyd460
X2. Did you mark your lifters for direction, and location. I would very strongly suggest doing a bit of reading before you go much further.
Exhaust are longer than intake. Please familiarize yourself with the pushrods install, and lifter bleed down before you go much further.
Old Jan 21, 2019 | 03:20 PM
Nunya Business's Avatar
Nunya Business
Stage II
Not helpful at all. Were you bored and decided to be obnoxious and uniformly un-helpful? Good job, you're a master.
Old Jan 21, 2019 | 03:24 PM
skid_pimp's Avatar
skid_pimp
You joined, to complain about a six year old thread? Impressive....
Old Jan 21, 2019 | 03:26 PM
Kingglide549's Avatar
Kingglide549
AT least someone else is getting slapped beside me.....
Geesh, dude, you get told the honest truth and you want to be spoon fed
Old Jan 21, 2019 | 06:16 PM
Nunya Business
Stage II
Yep 😁
Old Jan 21, 2019 | 09:21 PM
hattitude's Avatar
hattitude
He needs to respond, "Nunya Business".... !
I crack myself up.....
