Mechanic messed up cam timing, long term effects?
Old Mar 19, 2013 | 06:57 PM
todderickson's Avatar
todderickson
Default Mechanic messed up cam timing, long term effects?
Had the local dealer install 255's on my new ultra classic and the mechanic couldn't get it to run properly. After going through the electrical system and finding nothing wrong they decided to pull the cam cover and check timing of the cams. They were not timed right and they fixed it, now its running fine. My questions are: Will running the motor with the cams not timed correctly damage any other engine components? It was started and ran for short periods of time the last couple days trying to troubleshoot. Can or will there be any long term or lingering effects? Maybe issues that show up in 10000 miles? Or am I being too paranoid after spending this kind of money that I may end up with a lemon because of the mechanic screwing up this cam job.
Old Mar 19, 2013 | 07:09 PM
Harleycruiser's Avatar
Harleycruiser
As long as a valve did not hit A piston don't worry about it. Your good to go.
Old Mar 19, 2013 | 07:10 PM
dawg's Avatar
dawg
You should be ok. There were incorrect stamped 255 cams awhile back. Not saying it wasn't the mechanic's fault, but it could have been an old set off the shelf with mis-marked timing marks.
Old Mar 19, 2013 | 07:19 PM
todderickson
Thanks for the quick replies! I take delivery of it tomorrow, unfortunately we have a couple feet of the white stuff so no riding for a while. I am glad to hear everything should be fine with my bike.
mfortkamp's Avatar
mfortkamp
Clearance engine no problems....
Randy L. Beckner
Mar 30, 2019 07:24 PM
mooch78
Dec 13, 2012 02:27 PM
harleyman1340
Apr 10, 2010 10:20 PM
mgmmgm
Exhaust System Topics
Mar 13, 2010 06:22 AM
dtimekw
Ironhead
Jun 30, 2008 08:25 PM
