stereo problems
Old Mar 24, 2013 | 08:51 AM
foundry guy's Avatar
foundry guy
Default stereo problems
installed J & m fairing & saddlebag speakers & bazooka 200 watt amp on my 2010 road glide custom. sounds wonderful sitting still but begins cutting out once the bike starts picking up speed. all the wires were plug & play. how can i fix this? thanks
Old Mar 24, 2013 | 09:00 AM
marvincbr's Avatar
marvincbr
I would look to see if you have a loose connection, possibly power to the amp. If it sounds good when not moving and cuts out when in motion, seems like something is loosing connection from vibrations.
Old Mar 24, 2013 | 11:29 AM
06Cummins's Avatar
06Cummins
double check all your grounds, tighten all your connections.
Old Mar 24, 2013 | 11:37 AM
mtgriz's Avatar
mtgriz
How does that amp get its signal to turn on? What does rem wire connection look like?
Old Mar 24, 2013 | 12:26 PM
sublime_ac's Avatar
sublime_ac
MAke sure the ground lead is making good contact, not just tight, but has good metal contact.
Got any pics of how you installed it?
Old Apr 15, 2013 | 10:02 PM
2010FLHTCU's Avatar
2010FLHTCU
I have the same amp with the same problem. Did you figure out what the problem was? Just took it for a short ride tonight and noticed it cutting out. Haven't looked for the culprit yet.
Edward Evans
Audio Systems
Apr 22, 2019 03:11 PM
Harleypingman
Audio Systems
131
Jun 14, 2016 07:03 AM
uwiik
Audio Systems
Nov 5, 2013 08:00 AM
foundry guy
Audio Systems
Mar 24, 2013 09:16 AM
zeus33
Jun 6, 2012 02:48 PM
