1999 Road King
Who do you folks recommend for parts. I am hoping you have ideas other than HD. Or, EBay. I would want to do the work myself. I relax when I am doing such things.
My homework seems to indicate that the stock engine is an 88 engine. Am I correct? That seems to be the size for 1999. Instead if having the parts machined - can one have that done? - I would be thinking of buying jugs and pistons. Probably the next size up that would fit.
Is it common to have the heads worked over? Shaved to make sure they are flat? Have the valves worked? Or, just buy new complete heads?
Is this an EVO?
Any input would be appreciated.
(for $1500, if it runs I'd buy it!)
That's 88 cubic inches, and 1450 cc. The EVO was 1340cc. In '99 both the Twin Cam and EVo were available, although the bigger bikes like the RK normally came with the Twin Cam. Machine work can be done with all that you mentioned, bored oversize/headwork, etc. All very common...
(The only limitation would be your bank account!)
I believe the largest you can go without having crank replaced is up to 95". Higher CI would require smaller flywheel(s) to accommodate a longer stroke and piston rods. Plenty of choices as to who/where to buy...
As for your oil leak, although may not be your leak problem, the early TCs had a slight problem with the wires coming from the stator in the primary case. Oil sloshed around enough that oil would get pushed up the insulation of the wires, and drips out just under the oil filter where the insulation jacket ends for the connector. Wires are insulated and inside a rubber housing/jacket similar to heat shrink but not heat shrink. The oil gets between the two. Harley's solution is to reroute the wires up the left frame tube and back down again on the right frame tube. Why fix it when you can defy gravity so easily?
There were a couple other problems with the early TCs such as cam chain tensioners, rear cam sprocket bolt, main breaker (on some models), and some of the swing arms were known to crack just before the axle mounts.
Welcome to Harley Davidson's world!
(Don't let that discourage you, I've only touched on a few things. Others will come in with more, I'm sure!)
BTW, I own a '99 RK, and I love everything I fix on it!
Mike
I am guessing the VIN will give me engine size and type.
I think it could be a fun project. And, since it runs, I will not have to figure out why it doesn't.
Make sure when in the engine to replace the cam tensioners and bearings. These were problems with the early 88" motor. And while you are in there put in a better cam.
Does it have a carb or EFI?
I wouldn't give up my carb for nuttin!
For parts... Harley? or, another company?
Carb, I believe. Did not look that close.
Is there not a part that keeps the inner drive chain taut? And a "Compensator"?
