View Poll Results: Dynabeads or Ride_on
Dyna Beads
45
48.39%
Ride On
48
51.61%
Voters: 93. You may not vote on this poll
Dyna Beads or Ride-On?
Old Mar 29, 2013 | 06:08 AM
  #41
reg26's Avatar
reg26
Deffinetly not snake oil. Eagle Rider now uses it in ALL their rental motorcycles, read here
http://www.ride-on.com/motorcycle-formula-mot.html
I have also riddin with it at 140+ mph with no prob but that wasn't on my Harley
I've been using it for years but only recently for balance too
Old Mar 29, 2013 | 11:23 AM
  #42
slhanks4's Avatar
slhanks4
Dynabeads actually work. I have used them for thousands of miles on my previous bike. I don't like putting runny goop in my tires, so I would never use Ride On.
Old Mar 29, 2013 | 11:32 AM
  #43
Notgrownup's Avatar
Notgrownup
I thought the same until i tried it and when My Indy shop replaced my tire he barely noticed the stuff was in there...I was pleased with the results...
Old Mar 29, 2013 | 11:35 AM
  #44
mike_oh's Avatar
mike_oh
Ride-On is used by the U.S. Military and many government agencys. It works!!
Old Mar 29, 2013 | 12:54 PM
  #45
Pete6114's Avatar
Pete6114
It's not like that green slime tire sealant at all, that all wrenches hate. This is just on the tire, ready to seal a puncture if one occurs. And balances in the meantime.
Old Mar 29, 2013 | 03:47 PM
  #46
tubeman426's Avatar
tubeman426
Does anyone have experience with ride on in tubes?
Old Mar 29, 2013 | 04:03 PM
  #47
Kingers103's Avatar
Kingers103
Not to seem to ignorant, but I thought that this stuff went into the tire through the valve stem like the WalMart goo. Are you saying that this is applied to the inside of the tire while off the rim? I might consider trying it if this is the case. I was always under the assumption that you sprayed RideOn from a can through the air valve and into the tire. (Again, maybe ignorant)
-K
Old Mar 29, 2013 | 04:14 PM
  #48
Tom84FXST's Avatar
Tom84FXST
Old Mar 29, 2013 | 04:24 PM
  #49
Pete6114's Avatar
Pete6114
-K
You're right. It goes through the valve stem. It ends up attaching itself to the rubber and not the rim, as in the video slhanks4 posted
You get a tube with the bottle, attach it to the valve stem and squeeze the contents in. How much, depends on the tire size. They have a calculator on there site.
http://www.ride-on.com/calculator.html
Old Mar 29, 2013 | 05:04 PM
  #50
troop's Avatar
troop
Run the sealant bottle under hot water just before installing it. Flows much easier...
