Cam choice vs cubic inches
Old Mar 28, 2013 | 08:46 AM
0ldhippie's Avatar
0ldhippie
Short answer, NO. Cams need to be matched to the engine. Andrews makes different cams for 88 (26)-95 (37)-96 (48h)-103 (57h) engines for a reason. As a rule larger engines can use more duration and lift without getting lopey or losing bottom end.
Old Mar 28, 2013 | 11:31 AM
sublime_ac's Avatar
sublime_ac
The primary reason you won't want a cam designed for a 96 / 103 is the stroke is different than your motor. The older grinds that were designed for your motor are a better option.
If I had an 88" I would punch it to 98" and run the Andrews 37. That will put you just over the 100/100 mark and be a very rideable machine.
Old Mar 28, 2013 | 11:56 AM
Harleypingman's Avatar
Harleypingman
Originally Posted by just plain john
No racing is in the plan, but I would like a little more 2 up grunt.
Go with Andrews 21--earliest torque of the popular cams which you'll appreciate 2-up.
Carl
Justind
Jul 28, 2017 10:50 AM
mayhem912
Feb 21, 2017 06:42 PM
bedelman10
Engine Mechanical Topics
98
Jul 21, 2016 07:00 PM
DADAWG
Exhaust System Topics
Nov 22, 2008 05:39 PM
hondo96inch
14
Sep 18, 2007 10:07 AM
