TREX
Old Feb 16, 2007 | 03:15 PM
tgaetto's Avatar
tgaetto
Default TREX
I am picking up a set of Trex pipes tomorrow and I am currious how they mount? I sold my stock pipes and the starter bracket and trans bracket went with. Am I going to need brackets? Bountyhunter?
Old Feb 16, 2007 | 03:30 PM
bountyhunter's Avatar
bountyhunter
Default RE: TREX
Tranny/starter brackets went in the dumpster...with the stock exhaust. 4 manifold nuts/4 rear bolts...simple install!
Old Feb 16, 2007 | 04:00 PM
tgaetto's Avatar
tgaetto
Default RE: TREX
Awesome!
THANKS!
Old Feb 16, 2007 | 10:16 PM
ritorres's Avatar
ritorres
Default RE: TREX
This link has everything you need to know WRT the installation:https://www.hdforums.com/m_279878/tm.htm . The following postingshelped me with the installation:
Electra Geezer -> RE: T-Rex 3" Dual Straights (2/15/2006 12:41:09 AM)
quote:
(1) 4 bolts and 4 washers. 2 bolts and 2 washers per muffler to hang the mufflers from the stock bracket under the bags. [/b]
(2) 1 bolt and 1 nut to hold the rear pipe to the new bracket that goes on the starter after you remove the stock bracket. There are 2 bolts that hold the starter in place and the stock bracket. Pull the bolts out about 1 inch and remove the stock bracket. Install the new bracket and reinstall the 2 bolts. [/b]
(3) 2 - 1/4" thick spacers are used to move the right side floorboard further away from the frame allowing clearance for the front pipe.[/b]
(4) The clamp. I don't have a clue...
bountyhunter -> RE: T-Rex 3" Dual Straights (2/15/2006 8:25:31 AM)
Easier to install than to taking off the stock system (dumpster). I discarded the starter/tranny brackets and reversed the lock washer on the bottom rear board bracket. Trimmed the lower push pin on the left side cover a little, no problem. [/b]Then just 2 nuts to the manifold and 2 bolts to the rear mount, that's it. Best to get 4 new manifold nuts and trash the old ones. Been smiling ever since, these pipes ROCK!
Old Feb 16, 2007 | 11:32 PM
Kreuzen's Avatar
Kreuzen
Default RE: TREX
...that's the beauty, no stink'n brackets! By the way, did I say they are loud and sound awesome!
Old Feb 17, 2007 | 12:14 AM
tgaetto's Avatar
tgaetto
Default RE: TREX
Loud is what I am looking for! Thanks everyone this forum is the best!!!!
ORIGINAL: Kreuzen
dc1057
Jul 23, 2013 03:52 PM
2black1s
Feb 2, 2011 06:02 PM
Sparky88
May 5, 2010 07:51 AM
jterp
May 3, 2007 10:22 AM
Pilzner
Feb 8, 2007 06:34 PM
