So I've got everything I need to start installing my PYO 10" MBB's (hopefully get to it this weekend) on my 2012 Limited.
One of the recommendations I read here was to change out the rubber bushings for the stiffer polyurethane ones. Easy enough, got the parts (56298-03).
Now I'm reading in a couple threads that people with Batwing fairings are having to take about a 1/4" off the bottom of the risers because the combination of the larger diameter bars and the poly bushings being slightly higher than stock isn't allowing the switch cover to back on correctly (risers sit too high).
My question is, is there a set of Poly bushings you can buy that wont have this problem?
I think the threads you are seeing are related to the RK. I did them for my 10 MBB and had no issues other than trimming some rubber off the gaskets that are attached to mini faring for the ignition. Its worth doing them I originally installed them with the stick and noticed alot of movement when I changed them out it made them nice and stiff and no you dont get anymore vibration than the stock
They are designed with that thicker top and bottom so they isolate better.
Yeah I had to shave the piece your describing but it had more to do with the bars being thicker than anything else. I just ground it down real careful like...no big deal. Take a look you really cant tell.....
