Power Vision mounting options
Old Apr 6, 2013 | 11:41 AM
7Sixpack7's Avatar
7Sixpack7
Default Power Vision mounting options
I bought a PV and a tall boy mount from Iron Aces to mount to my 2011 fltrx. My question is what are others using for a detachable mount that attached to the Iron Aces mount to easily remove the PV from the bike without having to unscrew the PV every time I leave the bike?
Thanks!
Old Apr 6, 2013 | 11:53 AM
BrownSanta's Avatar
BrownSanta
i had it on a removable mount on my handle bar till i hit a hard bump and watched it fall off and slide into the sewer. So i went and got a kuryaken fuel door mount and its screwed into that with a locking pushbutton lock
Old Apr 6, 2013 | 02:55 PM
batman4706's Avatar
batman4706
Mine came with a visor with a detachable mount. I just push the tab and take it off. I've been over some pretty big bumps and never had problem. I do have Ohlins 3-3 shocks.
Old Apr 6, 2013 | 03:31 PM
smitty901's Avatar
smitty901
Yep and it works great . If you want to just pull it off use the sun visor mount from Dyno jet 19 dollars with your Iron Ace.
To keep from blocking the radio at all with this use the small black spacers to move it out a bit and mount using top two screws only works great.
This goes on your Iron Ace You power vision just snaps in to it. Those slot you see on your Power vision line right up with the two clips. Any question just yell.
Then you end up with this
No blocking of the radio view at all
Old Apr 6, 2013 | 07:20 PM
elbohead's Avatar
elbohead
That looks real clean. I've had my PV mounted to a POS plastic handlebar mount and used my Iron Aces mount for my phone. I think I'll go the other way around.
Old Apr 6, 2013 | 07:36 PM
BrownSanta's Avatar
BrownSanta
same one i have and no longer use!
skip v
11
Sep 6, 2018 10:56 AM
Bodacious MC
Jul 25, 2016 09:44 PM
ebeattie
Mar 31, 2013 03:01 PM
The Q
Touring Parts
Sep 29, 2011 03:24 PM
leadman
Feb 28, 2010 02:34 AM
