Changed fork oil. Now leaking
Old Apr 7, 2013 | 10:20 AM
Snowmaster113's Avatar
Snowmaster113
Default Changed fork oil. Now leaking
Changed my fork oil yesterday. Came out to the garage this morning and seen a puddle on the floor. The drain plug is leaking. Tried loosening and tightened back up and still leaking. Do the little copper washers go bad. I thought they would be fine to re use
Old Apr 7, 2013 | 10:30 AM
grbrown's Avatar
grbrown
Red face
You'll probably find the service manual says to replace with new, even though many of us will reuse them. Now you know why the manual says that, sometimes they decide not to play. Just get new ones and hopefully all will be fine....
Old Apr 7, 2013 | 10:31 AM
Juan L's Avatar
Juan L
Moderator
Most of the time they are a one use. I change my oil from the top so I can be sure to get the old stuff out.
Old Apr 7, 2013 | 10:51 AM
toothmansteveb's Avatar
toothmansteveb
I have found it best to replace the copper washers on the drain screws and the rubber oil seal under the top fork bolt. A few extra bucks is worth not going back to fix a leak.
Old Apr 7, 2013 | 10:54 AM
Snowmaster113
Yeah I was wondering if I should have got new ones but being the dealer is about an hour away I would try to get by without replacing. So much for shortcuts. Thanks for the Info guys. Live and learn I guess
Old Apr 7, 2013 | 10:58 AM
grbrown's Avatar
grbrown
Unhappy
It's a bummer I know and most times we get away reusing things like that, but then one day Fate decides we need to learn a lesson!
Old Apr 7, 2013 | 11:21 AM
Garret_GCD's Avatar
Garret_GCD
question about chaning the oil.. i just put RK shocks on my nightster.. and i think they are empty, how much oil and what kind is best to fill it up? also if i fill from the top what should i use?.. thanks!
Old Apr 7, 2013 | 11:32 AM
XARAN's Avatar
XARAN
The washers are usually 1 time use.
Old Apr 7, 2013 | 11:50 AM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Copper seals must be annealed. Heat them until dark red over the flame of a gas burner then drop in water. The gas kitchen range is sufficient.
Old Apr 7, 2013 | 12:30 PM
XARAN's Avatar
XARAN
This is off the OP thread but here is the best thread on shock oil change for touring shocks
https://www.hdforums.com/forum/touri...ur-shocks.html
Hope they work for you. Many of us trash the stock shocks , they are over sprung and poor dampening on a 800lb touring bike, cant see how they would work on a much lighter Sporty.
