How much will your does your MPG suffer by mods?
Old Apr 17, 2013 | 02:57 PM
HDSAE60's Avatar
HDSAE60
48 down to 34 you pay for power at the pump
Old Apr 17, 2013 | 06:38 PM
Mr HOG's Avatar
Mr HOG
When i did the 107 build on my Street Glide i went from around 40 MPG down to 35. I know the tune is correct - just the price you pay for more power.
Old Apr 17, 2013 | 06:43 PM
Rickey's Avatar
Rickey
If it is tune then I guess someone needs to show me what the heck I am doing wrong on my 96 with my PV. I have screaming eagle intake, Dragula pipes, and Andrews 48 cams. I get about 33. I do get on it every now an then but not often. Anyone wanting to ride to SC and give this a whirl just let me know. Beer stays in the fridge.
Old Apr 17, 2013 | 06:46 PM
12hdrk's Avatar
12hdrk
Originally Posted by Rickey
If it is tune then I guess someone needs to show me what the heck I am doing wrong on my bike with my PV. I have screaming eagle intake, Dragula pipes, and Andrews 48 cams. I get about 33. I do get on it every now an then but not often. Anyone wanting to ride to SC and give this a whirl just let me know. Beer stays in the fridge.
Most folks with stage one mods with a tuner report in the mid to upper 30's from what I've read in my limited time on this forum. 50's for a big build... I'm sceptical...
Old Apr 17, 2013 | 06:54 PM
Mr HOG's Avatar
Mr HOG
Every bike is different. You may indeed have a proper tune with your current mods. With the 1000s of different combinations available in mods you really have to compare apples to apples if you know what i mean. Just because some states they get 45mpg with xyz mods doesn't mean you will get the same mpg with abc mods. You'll find different mpg numbers even when comparing totally stock bikes. Of course, riding habits also affect mpg. If your bike runs well and you get somewhere in the 35-45mpg range then you've probably got a good tune.
Old Apr 17, 2013 | 07:37 PM
bwana1's Avatar
bwana1
[quote=chgofirefighter;11175005]Curious to know for those that have extensively modded their bikes, such as Headwork, Big Bore kits 107, new cams, etc etc on their 103 engine what did you notice on your mpg's?
I know that when you increase the compression, more fuel is being used. Don't know the specific when it comes to extensive motor work. Cam work alone will not cause you suffer much loss in MPG's? or whatever you do, matters?
I disagree. When compression is increased you are getting more hp from the same amount of fuel. If it takes "x" amount of hp to go 60 mph it will take less fuel to produce that same "x" amount of hp. When I increased the compression ratio on my Saltster from 9.5 :1 to 11.3:1 my milage increased by 5 mpg. However, if you are continually running WFO, milage will go domn.
Bwana
Old Apr 17, 2013 | 07:45 PM
12hdrk's Avatar
12hdrk
[QUOTE=bwana1;11181311][quote=chgofirefighter;11175005]Curious to know for those that have extensively modded their bikes, such as Headwork, Big Bore kits 107, new cams, etc etc on their 103 engine what did you notice on your mpg's?
So just to extend your logical thought.. You increased your compression from 9.5 to 11.3 so you could observe 5 more mpg?? Wtf?
Just kidding..
Old Apr 17, 2013 | 08:19 PM
vizcarmb's Avatar
vizcarmb
Originally Posted by DK Custom
A properly modded bike should have more power and get better MPG than a stock one.
The drop that most see is either from playing with the extra power, or from badly matched upgrades/inefficient tune.
They come from the factory tuned for emissions, this is not the same as being tuned for the best MPG.
What about stock bikes that get bad MPG in the first place? My 2011 never got past 35mpg when stock. Even with 5k miles still not getting anything over 35mpg
Old Apr 17, 2013 | 08:42 PM
2012SuperGlider's Avatar
2012SuperGlider
Sounds to me like most of the time people get worse mileage after mods. To me this would be a problem to me as I plan on doing some long road trips. Right now I am getting 48 mpg in mixed driving (mostly city) so I would expect at least low 50's out on the open road. Dropping down to 35 would suck.
How many people out there can honestly say that they are getting at least the same if not better mpg after a stage I?
Old Apr 17, 2013 | 08:45 PM
SteveMKentucky's Avatar
SteveMKentucky
[QUOTE=12hdrk;11181363][QUOTE=bwana1;11181311]
Originally Posted by chgofirefighter
I disagree. When compression is increased you are getting more hp from the same amount of fuel. If it takes "x" amount of hp to go 60 mph it will take less fuel to produce that same "x" amount of hp. ...
Following your logic my high-compression race engines should get better fuel economy than they did in street trim. Sorry, it doesn't work that way.
More compression results in more internal friction effect. More power developed by the engine tends to result in more heat losses. The ultimate result is usually more power but with lower fuel economy. The only exception is gaining power from internal efficiencies (such as efficient porting).
