Sick Horn
Old Apr 16, 2013 | 07:00 PM
Noble Jim's Avatar
Noble Jim
Default Horn Solution
Originally Posted by BigDawgQC
My horn sounds like it was stuffed with a sock. Anyone experience this and what is the problem or solution?
Thanks,
My solution was to replace it. I went with Kuryakyn Wolo air horn. Works great and its loud.
Ride on
Old Apr 16, 2013 | 07:11 PM
FLUltrarider's Avatar
FLUltrarider
Mine got wet once, sounded like a bloody sheep bleating then recovered. I changed the cover to a custom one and it just buzzed. Checked to make sure it wasn't touching the cover anywehere which it was, once I adjusted it, it was back to it's old self.
Old Apr 16, 2013 | 07:14 PM
pjb's Avatar
pjb
I never had to look at the horn on the bike, but most car horns have a screw or bolt in the side, turning it in/out will change the tone of the horn.
Old Apr 16, 2013 | 07:20 PM
soft 02's Avatar
soft 02
Originally Posted by blackflame
Mine does the samething, you think a bike that cost 20K would have a horn that works.
That would make sense if you didnt have as much flore space devoted to special parts as you do bikes for sale. These days the bike is just a down payment.
Old Apr 16, 2013 | 07:21 PM
Jackie Paper's Avatar
Jackie Paper
Mine sort of make a blugh sound too. However it is loud so I think mine's not broken. Sure not going to mistake it for a high pitch metric.. However like you I think the tone sucks. Sounds like a loud fat lady fart.
Old Apr 16, 2013 | 07:47 PM
checkers's Avatar
checkers
Thanks,
It has water in it or has had water in it. You can take it off and rotate it and drain/dry the water out of it. Replace it with stock or WOLO brand replacement off Amazon
Old Apr 17, 2013 | 03:19 AM
blackflame's Avatar
blackflame
Urgh,, isn't that the truth..
Old Apr 17, 2013 | 04:26 AM
reesestewww's Avatar
reesestewww
Any of these, Fiamm or Wolo, fit behind the factory cowbell?
Old Apr 17, 2013 | 04:52 AM
katobird's Avatar
katobird
Mine did the same...
Sprayed it with LPS , WD 40, PB Blaster or similar....
took a few minutes to soak in, pressed the horn about 4 or 5 times came back to life.
That was 2 yrs ago........works great
Old Apr 17, 2013 | 12:40 PM
Markymannn's Avatar
Markymannn
Did you end up replacing it with a Harley horn. Haven't looked them up....but I'm guessing $250?
I tried the draining (nothing in it), drowned it in WD40, adjusted and tightened bolts and nothing. Bought a Mini Beast for about $150 on-line. My bike has been in winter storage so as soon as I get it, it is going on
