Passing Lamp install
Old Feb 18, 2007 | 10:53 PM
sims5's Avatar
sims5
Default Passing Lamp install
I just bought a used set of passing lamps with the mounting bracket and the flat turn signals. I'm wanting to leave my bullet turn signals in the under the mirror location. The question is, where do I plug in the passing lamps, my Road King Custom has 2 aux swithces sort of behind the headlight. I'm guessing I can just remove the "flat" turn signals and not use them. Any thoughts would be appreciated. Thanks.
Old Feb 19, 2007 | 12:54 AM
SteelCityScooter's Avatar
SteelCityScooter
Default RE: Passing Lamp install
From your discription< I am guessing you bought a used set of EG passing lamps.
If this is true, you will have four wires coming from each side of the bracket. The Grey/Black wire on each side is your passing lamp, and the other three are for the turn indicator.
On the EG, all four wires go into the sameconnector and plug in inside the fairing. Connectors #31L and #31R (four place multilock)
On the roadking, the two passing light wires go into one plug and plug into a connector inside your headlight, Connector #73 (two place multilock and it is white) Looking into your headlight at the wiring, this connector is at about the 6 o-clock postionand have two grey/black wires.
The turn signal wires go to Connector #31 (6 place multilock) but you will need to splice in to run all four turn indicator lights in front.
Old Feb 19, 2007 | 04:34 PM
sims5's Avatar
sims5
My plan was to remove the turn signals that are below the passing lamps and just use my original bullet ones in their current location under the mirrors. Can the turn signals be removed or do they have to be there for the passing lamps to be secure? I don't have the unit yet, it is being shipped. From my memory, photo that I don't have in front of me there was some wires that had 2 connectors, I guessing 1 for the lamps and 1 for the signals. Do I have to remove the headlight to get to the connections that you are talking about?
If I decide to use the new signals and do away with my bullets, what would I do with the wiring that is currently going to my bullet signals?
Old Feb 19, 2007 | 08:14 PM
SteelCityScooter
The way it is setup on the ones you are getting, the lollipops are a part of the lower bracket where the lights mount.
The bracket at arrow #1 screws into the bottom of the passing lamp.
The piece at arrow #2 is part of the lollipop. the wires comeout where those two meet.
[IMG]local://upfiles/18109/6DA973E3186047B79D87C5FC46F696F6.jpg[/IMG]
The turn signal wires go to Connector #31 (6 place multilock) but you will need to splice in to run all four turn indicator lights in front.[/u]
If you choose to just use the lollipops, you will take the wires from them and insert them in the 6 place multilock that your existing wires are in now.
And the two grey wires will go to the other connector. Before you buy them,I would make sure they were taken apart from the connectors, and not cut.
If they were cut, you may possibly need to add wire, and connector"pins" to make them work on your setup.
To answer your other question, yes the wiring is behind your headlight on a roadking.
Old Feb 20, 2007 | 12:12 AM
sims5's Avatar
sims5
appreciate the info.....I'll have to wait and see when the get here. I'm pretty sure that in the pics that I saw there were connectors.
Old Feb 21, 2007 | 05:48 PM
sims5's Avatar
sims5
SteelCityScooter.....just wanted to say thanks for the info.....mounted the light bar today and plugged in the two plugs and everything worked perfect. I love it when that happens!
Old Feb 21, 2007 | 06:39 PM
whateva's Avatar
whateva
Take some pics if you get a chance. I would like to see what it looks like.
Old Feb 21, 2007 | 08:14 PM
dmize's Avatar
dmize
ya I want to see that custom with those new hard bags and lights =P should look pretty dam good.
dan
Old Feb 21, 2007 | 11:06 PM
sims5's Avatar
sims5
I started a new post earlier with these pics but since you guys asked here are the before and afters in case you didn't see the other post. I really like the look. Now I just need "whateva" wheels, those are sweeeeeet!
Before
[After]
Before
After
Old Feb 21, 2007 | 11:22 PM
SteelCityScooter
Looks good, glad it all worked out for you.
