Power Vision Autotune Basic Help?
Old Apr 21, 2013 | 10:05 PM
nirschl's Avatar
nirschl
Default Power Vision Autotune Basic Help?
Hi folks,
I'm out on the road trying to do this Autotune basic. When I go through the process to the half way point, on the top left my power vision is telling me "Auto Tune NOT Active."
Any help here? Is there something I'm missing. I followed the steps exactly from Dynojets video but I getting thy message and cannot select "Datalog" to finish the process.
Help much appreciated!
Cheers
Old Apr 21, 2013 | 10:23 PM
$tonecold's Avatar
$tonecold
Originally Posted by nirschl
Hi folks,
Cheers
What year model is you bike? Does it have O2 sensors? If you do have O2 sensors go to autotune, settings, and reset to default and try again.
Old Apr 21, 2013 | 10:43 PM
nirschl's Avatar
nirschl
Thanks!
2010 limited. The ECM is currently flashed with a FM map that came with it. I'm assuming it's firmware is up to date as I just got it a few weeks ago. I'll try the reset right now.
Old Apr 21, 2013 | 10:49 PM
nirschl's Avatar
nirschl
Just tried it and still not working...
Still saying "Auto Tune NOT Active."
Now I've not had this unit connected to a pc yet. Is that required at all to iniciate an Auto Tune Basic process?
Sorry for the questions...I'm on the other side ofte world right now and cannot make a call to FM, at least until the am. Just wondering if others out there online have experienced this.
Cheers
Old Apr 21, 2013 | 10:54 PM
nirschl's Avatar
nirschl
Pic of the map I'm try to modify:
Pic of what comes up after I do the 10sec ECM restart:
Old Apr 21, 2013 | 11:01 PM
Dr. Tiki's Avatar
Dr. Tiki
You have to select "Enable AT" then select the Tune that you want to Auto Tune to start logging against.
So select Enable AutoTune... Select your Tune, flash the ECM. Go back into that screen and select Datalog.
nirschl's Avatar
nirschl
A quick video of what's going on:
http://i952.photobucket.com/albums/a...ps8ce1cbbf.mp4
After restart:
http://i952.photobucket.com/albums/a...ps2956b8f7.mp4
Old Apr 21, 2013 | 11:03 PM
nirschl's Avatar
nirschl
Hi there, yep. I did that. Just threw up a quick video to show you what I did. The second pic your seeing is what comes up after doing what you said. Step by step from the dynojet video, except this is far as I'm able to get to. Cannot select "Datalog."
If I'm doing something here, don't worry, I'll flame myself!
Thanks!
Old Apr 21, 2013 | 11:09 PM
Dr. Tiki's Avatar
Dr. Tiki
On mine when flashing the ECU, the PV will throw up a message telling me turn the ignition off for 10 seconds. In your video it seems you were shutting off your bike before the message came up.
Old Apr 21, 2013 | 11:32 PM
nirschl's Avatar
nirschl
Consider me flamed and fried, my friend...problem solved.
Man, I'm a moron...figured that had to be the case. Thanks a bunch!
Cheers
