Power Vision Autotune Basic Help?
Old Apr 21, 2013 | 11:53 PM
Dr. Tiki's Avatar
Dr. Tiki
Just because I took the effort to make a video to show you mine... I'm going to link it anyways though you found your problem.
Old Apr 22, 2013 | 05:18 AM
nirschl's Avatar
nirschl
Thanks a lot for taking the time to do that, friend. I was checking my phone for updates while I was out on the road and saw your previous post. I pulled off to the side of the road and right there the problem was solved. I started a new log and ran the bike for another 30-40mins. Re-flashed the ECM with the new tune and it was instantly smoother. It was darn close already I thought with the FM map. But something smoothed out. Acceleration and shifting was easier I believe.
I'm still learning all this stuff...I'm sure it'll never end.
Thanks again! Cheers
Old May 4, 2013 | 05:05 PM
Warren9073's Avatar
Warren9073
Default Glad the OP got his problem solved...
I have run Auto tune several times now and eachtime seemed successful but when I do a compare in WinPV there is absolutly nodifference.
I started with the map from Fuel Moto. I ran a data log for about 15 minutes. I had a lot of RED boxes on the screen unlikethe videos I have seem with all green numbers. I hit exit on the datalog screen (with the bike still running) and savedthe tune to an empty slot. I then shut the bike off and flashed the newtune. I ran the process again only thistime using the saved Autotune as the starting point. When done with both tunes and flashes I connect the PV to my PC and do acompare. No differences at all.
Anyone have any ideas? Why do I see so many red squares when data logging and why don't I seeany differences in WinPV? When I comparethe two maps sent by FM I can see differences.
Sorry I posted this in the touring section. One more thing is that when I stopped data logging it said "0% difference and 7% max" yet the screen had a lot of red squares .
Old May 4, 2013 | 10:09 PM
$tonecold's Avatar
$tonecold
The squares turn red when they have had enough hits to datalog, it doesn't necessarily mean there is a change. Before you do a tuning session are you doing a reset on the trims? This is on page 4-50 in the WinPV User's Guide. When you do the compare are you doing this in the VE tables? That is what changes when you auto-tune. If there are no changes it may be that it is a good tune.
Old May 4, 2013 | 10:37 PM
Warren9073's Avatar
Warren9073
Thanks $toneCold
I didn't know that about the red but I did have my WinPV in Basic mode and did not see the VE tables. After setting the option to Pro mode I can now see the changes made.
Old May 5, 2013 | 12:11 AM
user 8373900's Avatar
user 8373900
I just installed my PC Vision after having a PC5 and at the very end when they ask you to turn off the ignition for 10 seconds, I didn't select OK first. Did it still load the map? Or maybe I should re-load..
Mark
Old May 5, 2013 | 07:51 AM
Warren9073's Avatar
Warren9073
Mark
I did that to but I really don't think it makes a difference. At that point the only important thing is that you power it off.
Old May 5, 2013 | 10:05 PM
ke5rbd's Avatar
ke5rbd
Mark
Yes it still loaded it.
Old May 5, 2013 | 10:09 PM
user 8373900
Thanks, took it on a 250 mi shakedown today and clocked 49 MPG 2 up? And it runs better than the PC5 did Holy Moly!!
Mark
rrogers4
Fuel Moto / Jackpot Mufflers
Mar 6, 2014 11:16 AM
Loc_Tite
Apr 18, 2013 11:03 AM
Rhonda
Feb 15, 2013 03:32 PM
gant
Aug 16, 2012 11:35 AM
Hrlyrider
Mar 7, 2010 08:51 PM
