Wobble
Old Apr 23, 2013 | 07:29 PM
berndog's Avatar
berndog
Default Wobble
I own a 2001 Road king Classic,,,just went on a 4 day trip over the coquihalla hwy andd back,,rode great,except in long sweeping corners,,,,it gets this wobble,like a snake,and I have to slow right down,,scared the daylights out of me,,,Any ideas?
Old Apr 23, 2013 | 07:34 PM
dawg's Avatar
dawg
Check steering head bearing for starters as well as tires.
Old Apr 23, 2013 | 07:54 PM
rwtrick's Avatar
rwtrick
You might consider adding a frame brace - search the subject on the forum lots posted about this. I put the Progressive Touring Link on my 08 RKC, great improvement.
Old Apr 23, 2013 | 08:07 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
stabilizers are good but...check the steering head bearings and even swing arm bushings and motor mounts first.
Old Apr 23, 2013 | 08:08 PM
bigdumbnoitall00
and if ya got spokes give them a going over.
Old Apr 23, 2013 | 08:22 PM
Proud Marine Dad's Avatar
Proud Marine Dad
PHP Code:
improvement
Worked great for me.............after I checked everything else of course. No more wobble.
Old Apr 23, 2013 | 08:38 PM
btsom's Avatar
btsom
You have experienced one of the main reasons that "bagger braces" are popular add-ons especially on the pre-09 frames. If you Google "bagger brace" you will probably find out more than you ever wanted to know and then have trouble making a decision. I opted for the Progressive link because the part that mounted to the frame was made of steel, not aluminum. I's certain aluminum is up to the job, but dis-similar metals in contact with each other tend to corrode. I didn't want the brace mount or that part of my frame turning to powder over the years. It was also among the more competitively priced options.
As others have mentioned, be sure the basics are healthy first, then with the brace things should be more stabile than you have yet experienced.
Old Apr 24, 2013 | 06:14 AM
grbrown's Avatar
grbrown
Wink
There are various things that can contribure to the wobble, including poor tyre wear, low tyre pressures, swingarm bushings worn, engine rubber mounts worn, steering bearings out of adjustment or worn. Check all of those, then read my bagger wobble thread.
Old Apr 24, 2013 | 06:37 AM
TKDKurt's Avatar
TKDKurt
2011 RKC, just like yours, and well maintained. 19,000 miles under every riding condition you can think of. No wobble or hint of wobble. Ever.
Have the maintenance items others have mentioned checked. Start with the easiest one--tire inflation. You don't need a frame brace on a 2011.
I don't know what your experience level is, but I think many newer riders do a "death grip" on the bars in a long sweeper and even try to steer (as opposse to relaxing and trusting the countersteer). If you think you fit that category the "wobble" will go away with experience.
Old Apr 24, 2013 | 07:10 AM
Trial dog's Avatar
Trial dog
Except his is an '01, not '11.
