Wrong Head Gasket installed.
Old Apr 25, 2013 | 10:38 AM
harleyrk50's Avatar
harleyrk50
5th Gear
Unhappy Wrong Head Gasket installed.
I had some great work done on my roadking. 88" to 98" at Hillside Motorcycle Co. In Munnsville, NY. The guy that put the engine work back together(Behind Bars in Ballston Spa, NY) apparentlyu used the wrong head gasket resulting in too muck compression. 210psi instead of 195psi max. Just what king of damage can too much compression do to a engine?
Old Apr 25, 2013 | 10:39 AM
KCFLHRC's Avatar
KCFLHRC
Doesn't sound like great work to me
Old Apr 25, 2013 | 11:08 AM
0ldhippie's Avatar
0ldhippie
I don't know anything about your build but I don't think that 5# is a big deal?? A good tune should take care of it.
Old Apr 25, 2013 | 11:13 AM
QC's Avatar
QC
120# in both or just one?
Give Scott a call, he'll be more than happy to help you out.
Old Apr 25, 2013 | 11:17 AM
modes's Avatar
modes
Not sure. I would assume cam in it would play a major factor in answering your question though. Calculation of the compression ratio not just the compression reading will also aid others in giving much better answers. I.E. If correct thicker (assumed) head gasket was used your build was supposed to be X:1 compression, but it is Y:1 compression now. There are some high compression bikes out there. Run it 'til something lets got then fix it how it was supposed to be.
Adam
Old Apr 25, 2013 | 11:44 AM
ReapersWG's Avatar
ReapersWG
Need more info. Check your CCP and then with your parts and cc's of your heads use the Big Boyz calculator to do some reverse math and it should give you a idea of the HG size used and tell you your estimated CR
Old Apr 25, 2013 | 11:49 AM
aces&8s's Avatar
aces&8s
I thought 160 psi is normal?
Old Apr 25, 2013 | 11:56 AM
GaugeMods's Avatar
GaugeMods
Former Sponsor
Originally Posted by harleyrk50
I had some great work done on my roadking. 88" to 98" at Hillside Motorcycle Co. In Munnsville, NY. The guy that put the engine work back together(Behind Bars in Ballston Spa, NY) apparentlyu used the wrong head gasket resulting in too muck compression. 120psi instead of 115psi max. Just what king of damage can too much compression do to a engine?
Is this CCP? I think CCP should be 160 min average 180 and high comp could be 195-215
if your ccp is 120 I think your are too low and something is wrong. JMO
Old Apr 25, 2013 | 10:47 PM
aces&8s's Avatar
aces&8s
Stock Evo engine is average 165. somtin wong fo sure.
Old Apr 25, 2013 | 11:24 PM
Harleypingman's Avatar
Harleypingman
Who are you listening to?
How was it the wrong gasket?
Have you talked to the guy who did the work?
At this point you seem clueless, which many are when it comes to engine work.
Carl
