Compress forks?
Old Apr 25, 2013 | 08:03 PM
jrat69's Avatar
jrat69
Default Compress forks?
Getting my lowers powder coated now, and then will be installing the lowered monotubes. How hard is it to compress the springs when reassembling? I have seen post of home made compressors made from 2x4, and some say they use a ratchet strap, others say just apply moderate pressure with their hand. If it is that hard to compress should I take them to a local Indy to have that done? No one has posted any pictures of how any of the home compressions tools work.
Old Apr 25, 2013 | 08:18 PM
Harleycruiser's Avatar
Harleycruiser
Not touring, but how I do it.
Old Apr 25, 2013 | 08:20 PM
Joe12RK's Avatar
Joe12RK
I just put the upper nut in the upper triple clamp and then slid the tube thru the lower triple clamp and pressed up and screwed it in. Had to remove "coke cans" to give myself hand room. I didn't take pictures, sorry.
Old Apr 25, 2013 | 08:28 PM
senna's Avatar
senna
Depending on how much you lower it, it'easier. I recently put 2" lower mono tubes on and there is hardly any load on the springs at all. As a mater of fact, it kind of hard to torque the lower 6mm alen bolts due to the fact there is not much load on them.
Old Apr 25, 2013 | 08:50 PM
sanman4ever's Avatar
sanman4ever
I was a major PITA on my Street Glide....went with this.
Old Apr 25, 2013 | 09:04 PM
Scootr's Avatar
Scootr
I just did the install on my Ultra yesterday. I installed the standard height monotubes so I don't know how much difference there is between the two. It was easy and just pressure with the palm of my hand was enough. Over all install took longer than I thought at about 5 hours start to finish. That was the first time I tore the front end apart though. I'm sure I could do it in 3 next time. .02
Edit: Took it for a test run today and it feels good! I'm still hoping I did everything right but so far so good!
Old Apr 25, 2013 | 09:35 PM
senna's Avatar
senna
I took stock height mono tubes out to install the lowered ones, it is about the same effort for both but on the lowered ones you have less spring travel before the threads start.
Old Apr 26, 2013 | 02:46 PM
mrfuji's Avatar
mrfuji
Default compress
just put your top cap in a big vise grip side way.and push the tube in. and screw with the tube.mrfuji
Esp660
Aug 1, 2018 03:27 PM
Mark Edw
Aug 25, 2017 11:16 AM
Big trucker
Touring Parts
Feb 28, 2016 06:46 PM
2015 Harley Davidson Street Bob Guy
Nov 16, 2015 08:35 AM
EasternSP
May 12, 2011 12:55 AM
