Help
Old Apr 27, 2013 | 11:41 AM
kfstreetglide's Avatar
kfstreetglide
Default Help
What would cause my 07 streetglide to display trouble codes p1353
(Front cylinder no combustion) and code p1356 (rear cylinder no combustion). bike seems to be running fine, any insight would be helpful. thanks
Old Apr 27, 2013 | 02:47 PM
smithbrl's Avatar
smithbrl
Is the Check Engine light on? If you clear the codes, do they come back when you go for a ride? Check your plugs and wires. Make sure the wires are tight on the plugs. Are you running stock spark plugs? Any other codes?
Old Apr 27, 2013 | 02:55 PM
Gliden's Avatar
Gliden
I'm just regurgitating what I think I've read here before.
Those electrical connections by the throttle body that you got....carefully unplug them and replug them in tight.
Old Apr 27, 2013 | 03:08 PM
smithbrl's Avatar
smithbrl
I don't think his 07 has TBW. I'm not familiar with throttle body wiring for 07, so you could have a valid point.
Old Apr 27, 2013 | 04:53 PM
dawg's Avatar
dawg
Historical code. Clear them and you'll be fine.
philb252
Sep 10, 2013 09:26 AM
harleyman6971
Sep 8, 2013 03:31 PM
jurgie
Jun 11, 2011 06:02 AM
djpullen
Sep 11, 2010 05:41 PM
a21m
Mar 15, 2009 02:17 PM
