Open or closed loop???
Unless you are dealing with multi valve and ported fuel technology nothing is going to make that much difference between the option, agreed all improve the stock situation.
Unless I was really gonna do something with the head and cams I would choose the most economic solution open to me to release those few ponies restrained at the factory....other than that take your choice and go with that which appeals to you most......in most cases usually the most expensive seems best so go with that if it makes you feel better....
no offence to anyone just my rant....
R
To really take advantage of a closed loop system you need to add wide-band sensors to fully monitor and then feedback that information across the entire powerband to the ECM.
Wideband systems that work in closed-loop do exist, however. The PCV with AT option works with the PCV, not the ECM. Thundermax is a replacement for the stock ECM and it works with wideband sensors in closed-loop. The Rev. Performance EMS works with widebands after RP reworks the ECM to run with them. The PCV-AT costs $300 for the PCV and $300 for AT, and both T'Max and EMS cost more.
Open-loop operation is not as limited as some think. I've been running open-loop with my Power Vision for >2 years and it works well without any feedback from O2 sensors. I have wideband sensors installed, but they are only used for datalogging and tuning, and do not function at all in normal operation except for monitoring purposes. I do monitor Lambda (AFR) in real time with the PV display unit and I can attest that open-loop does keep AFRs in a fairly tight range, usually ±2%. When I perform datalogs I see average variances usually ±1%, and that's good enough to be unnoticeable to the rider, unmeasurable in fuel economy, and unmeasurable by any performance yardstick. The ECM uses other sensors on the bike (FCHT, intake temp, and MAP). They do a surprisingly good job of keeping AFRs as specified in the AFR table, even as altitudes and temperatures change.
There would be little use in tuning your bike on a dyno and then buying the AT-100 kit, as the latter is designed to tune the bike. Once you get a dyno tune you won't need the AT-100 at all, unless you want to fine-tune the tune, but if you do that you have little need for a dyno tune in the first place unless you have specific problems that need to be addressed. With the PV you can tune the bike yourself with either stock or WB sensors, but you can run closed-loop only with the stockers.
Not to belabor this, but a dyno tune does have its advantages. If you're trying to extract every .1HP out of the motor, for racing purposes or whatever, you are best served with a dyno tune. Any self-tuning device like the PV can only give you the AFR (Lambda) you specify, but proper values are well-known and you can get it very close without actually measuring HP/TQ.
