Adjustable backrest question
Old May 8, 2013 | 07:13 AM
rob0225's Avatar
rob0225
Default Adjustable backrest question
I have a question about the Harley adjustable backrest.
A indy shop down the road from me has 2 of the mounts used but when I pull the lever nothing happens. Is the backrest supposed to actuate with no pressure from the rider on it? Are just the pistons replaceable?
Thanks,
Robert
Old May 8, 2013 | 07:22 AM
Chucks1911's Avatar
Chucks1911
I didn't have mine on very long, but when I moved the lever when I was off the bike, the backrest would slam forward as far as possible pretty violently.
Old May 8, 2013 | 07:49 AM
yowflhtk's Avatar
yowflhtk
Thanks,
Robert
If not installed on the bike, the mount is likely in the forward position. It would be extremely difficult to move it by hand if not mounted on the bike. When mounted on the bike, you pull the lever and then push back on it to the desired position. I have one and love it.
...........martin
Old May 8, 2013 | 08:12 AM
chief1600's Avatar
chief1600
This is correct. And it's also correct that it's difficult at best to move it position if it's not mounted on the bike.
I have one but it doesn't go back far enough for my liking and consequently I'm considering getting rid of it. If I don't the only way I'll be able to make it work for me is to bend the bracket.
Old May 8, 2013 | 06:18 PM
K Melancon's Avatar
K Melancon
Also dont hit the lever unless the backrest is attached and you holding it with some resistance. It can spring forward hard and cut your seat.
Old May 8, 2013 | 07:16 PM
ssmith579's Avatar
ssmith579
I have the same issue with mine. I don't know why they make an adjustable backrest with such a limited useful range. I actually bent the bar of the backrest so it would lean back more and I'm pretty short. Silly design but it is a nice backrest.
Old May 8, 2013 | 08:03 PM
chief1600's Avatar
chief1600
How difficult was it to bend the bracket? I was thinking about just putting it in a vice and giving 'er hell. Is that what you did? If it's hardened steel it might be pretty tough.
Old May 8, 2013 | 08:12 PM
Twistnride's Avatar
Twistnride
It's not hardened steel. These guys doing all the whining,need to get the right seat,the backrest is not their problem.They work perfectly when the seat is right for the rider,and Harley has that covered pretty well,along with custom makers.
Old May 9, 2013 | 09:37 AM
ssmith579's Avatar
ssmith579
So glad that you're an expert on other peoples anatomy. I didn't realize how screwed up I actually was.
I wedged it in my table saw and leaned on it. It's pretty tough but it will bend.
Old May 9, 2013 | 09:40 AM
lionsm13's Avatar
lionsm13
Good to know, eh?
