I can't believe there is not a map from the setup I have. Very frustrated.... Now I have to wait until Monday to hopefully get a map from their tech support. No
riding this weekend....
I've got a 103 base map that would work. Run a couple basic auto tunes with it and your good to go. PM your email address and I will forward it to you. It came from fuel moto set up for 103 with true duals, intake and jackpots, but it should work well for you as a starting point and get you riding over the weekend anyway.
There should be some 103 touring stage 1 you could grab, it don't have to be exactly the same setup. You can even load a stock improved map and go from there with the auto tune. One or two runs and most of the VE's will have changed from where they were on the base map anyways.
You can go to Dynojets site and look up a map that is close to your setup and download a map from there. Then you can record your ride a few times to fine tune it.
There is a video that shows you how to run the auto tune / data logger. It's very easy to do. Use the standard mode, not the pro mode unless you changed your O2 sensors.
