First point of contact with road when banking to left
Old May 12, 2013 | 10:23 AM
davessworks's Avatar
davessworks
I'm going to test the kickstand theory and use the plywood test (had already done something very similar with a plank but not quite as good as it doesn't get the length in)
Old May 17, 2013 | 11:19 PM
JohnTM's Avatar
JohnTM
So, if I read correctly with my extendeded floorboards I should hear a scraping sound on a good turn?
Old Dec 24, 2014 | 11:31 AM
DJFireUSA's Avatar
DJFireUSA
Has nothing to do with a good turn. You can scrape in a parking lot.
Old Dec 24, 2014 | 11:44 AM
beary's Avatar
beary
The spring doesn't have to be a bad for the Jiffy Stand to scrape, many streets have a slight rise where it joins another street and that little bump will cause the spring to stretch just a tad. If you ever pick up a jiffy stand, you can understand why the weight of it helps flex the spring on bumps. The stands are very close to the road in left turns, so the spring doesn’t have to stretch much for the stand to scrape. You will get to where you see it coming.
Beary
Old Dec 27, 2014 | 12:26 PM
dougbk's Avatar
dougbk
Tab on the Jiffy Stand. I have had them sharpen up like a knife, actually had our wrench have to get stitches in his hand from the one on my 08. Now he hits it with a file before he services to take the edge off.
Doyle Schwengler
May 16, 2019 08:15 PM
rickyt'ssnakefarm
Oct 11, 2018 12:44 PM
docbhill
2014-2024 Touring Models
13
Jun 1, 2018 05:21 PM
brokefootkenny
Apr 19, 2018 09:45 PM
maher01076
Apr 9, 2018 06:47 PM
