Volt meter
Old May 11, 2013 | 08:31 AM
microwave's Avatar
microwave
Default Volt meter
Anyone out there have a volt meter in their bat wing spiking back and fourth?but not at a idle?
and what was the out come?
Old May 11, 2013 | 08:40 AM
jeffreydsilver's Avatar
jeffreydsilver
Default Just My .02
My initial "diagnosis" would be a bad connection somewhere. I'd take apart both battery cables, at both ends, clean them and put them back together. I might also try disconnecting the gauge connections, cleaning them and putting them back together again.
A dancing needle would indicate a poor connection. When at idle (a constant minimal reading) it wouldn't be as apt to show. Start off by looking for the obvious.
Old May 11, 2013 | 08:51 AM
williamfrog's Avatar
williamfrog
Couldn't say it better. Start looking for a loose or corroded dirty connection.
Old May 11, 2013 | 08:55 AM
Iceman24's Avatar
Iceman24
I'd agree in saying "Houston we have a problem." Good advice fm jeffreydsilver...start there.
Old May 11, 2013 | 09:00 AM
Gliden's Avatar
Gliden
I'd throw a volt meter on your battery to see if it's a regulator or charging issue by seeing what the voltmeter is doing while your needle bounces.
Old May 11, 2013 | 09:05 AM
Gliden's Avatar
Gliden
If you wInd up needing a new volt gauge I'll give you the one I took out of my 09 flhx.
I wanted a Dakota digital readout not the hd guess your voltage type.
Old May 11, 2013 | 10:27 AM
mrfikser's Avatar
mrfikser
I have seen that happen with a battery with a short in one cell...so you might want to get your battery checked..
Old May 11, 2013 | 03:51 PM
microwave's Avatar
microwave
Thanks for that Mrfiker...I'll check that 1st as I do all my joints/plugs with elero grease...its started happening after i wash the bike at a car wash...thinking maybe water got in the reg. or alternator plug....can't check it until i get back next Thursday...just wondering if it was a short or not.... it is acting like one....
Taterdog
Jul 25, 2015 09:00 AM
c50plus
May 12, 2014 08:09 AM
cgrnh
May 28, 2012 03:04 PM
nolabel
Mar 21, 2011 06:03 PM
essentialcycle
Aug 5, 2010 07:48 AM
