Handle Bar Question.........
Old May 11, 2013 | 12:42 PM
Houlie's Avatar
Houlie
Default Handle Bar Question.........
I have a 05 FLHTPI. Had a minor accident last night, bent the bars slightly. Two questions, would it make sense to try and straighten out the bars? Should there be any concern that structurally they won't be sound? It appears that the right hand side is lower by about an inch or so
Or I have a friend with a stock set of bars off of a Road King same year. What is the difference between the two? As I look at the schematic for my bike they show 3 different kinds, why were there 3?, and how do I figure out which one I have?
Thnx in advance guys
Old May 11, 2013 | 12:45 PM
mkguitar's Avatar
mkguitar
the bars may be bent--- or it could be the rubber mount bushings torn, or they could have slipped in the clamps.
look at that first.
whatever you do, you have to disassemble, so get in there are see what the fault is.
the RK bars have a narrow center section and will not clear the fairing
mike
Old May 11, 2013 | 12:51 PM
ramnj's Avatar
ramnj
Originally Posted by mkguitar
whatever you do, you have to disassemble, so get in there are see what the fault is....
X1
You HAVE to take it apart. If the handlebar is bent, I would replace it. The metal has been stressed at the bend and will only be a matter of time before they fail.
Old May 11, 2013 | 01:40 PM
bubdifab's Avatar
bubdifab
I have my stock 06 FLHX bars I can sell you for cheap if you need them.
GuitarKidd
2014-2024 Touring Models
17
Apr 19, 2019 12:11 PM
Mixter
Aug 23, 2012 09:35 PM
Roadrocket
Apr 20, 2007 05:37 PM
jsm562
Apr 12, 2007 04:34 PM
engineer
Mar 26, 2007 09:28 PM
