2005 Road King Problems/Maintenance
Old May 13, 2013 | 10:56 AM
folkxrock's Avatar
folkxrock
Default 2005 Road King Problems/Maintenance
Looking for some help/input. Are there any common problems or maintenance issues with the 2005 Road King?
I sold my FXDL a few years back and bought a 2005 Road King Custom with 4k on the clock. I rode the bike about 3500mi and then life took me in a different direction and the bike has been parked for a few years. It has been started occasionally and moved around the garage.
Life has settled down and I can start riding again, so I am looking for input on any maintenance issues I should address with the bike. I have this bike like I want it and I don't really have plans to sell it so I would like to be proactive and address any weak spots.
Thanks in advance
Old May 13, 2013 | 01:45 PM
cubalz's Avatar
cubalz
Change the oil and filter and air up the tires. I would check both tires for any signs of cracking or splitting, replace if necessary. Maybe replace both spark plugs.
Ride it around the block a whole bunch of times to make sure the brakes are operating fine and not hanging up and that the trans is shifting smoothly.
Legal disclaimer: This is just my opinion.
cubalz's Avatar
cubalz
Duplicate post.
Old May 13, 2013 | 01:49 PM
folkxrock's Avatar
folkxrock
Cubalz - Thanks for the reply, but I am actually trying to see if there are any specific issues with this bike/motor that I should address. I was not really talking about basic maintenance after removing the bike from storage. All good info though.
Thanks
Old May 13, 2013 | 03:24 PM
pit1600's Avatar
pit1600
Cam bearings and tensioners will be a must to do!
Old May 13, 2013 | 03:27 PM
Jackie Paper's Avatar
Jackie Paper
Worry about it at 25K. At the rate it's clocking miles, it will be years before you really need to do anything other then maintenance. Even that I would only do once a years.
Old May 13, 2013 | 03:34 PM
Harleypingman's Avatar
Harleypingman
There was a valve seal recall on the '05 and you can check if your bike has been fixed or not. Otherwise, the only common issue are the cam chain tensioners which most don't encounter, but enough do for cause for concern.
Carl
Old May 14, 2013 | 10:30 AM
folkxrock's Avatar
folkxrock
Carl
Is there an aftermarket replacement for the cam chain tensioners or a revised HD Part?
JaxHarleyRdr
The "Florida Crew" Classified Section
May 15, 2017 09:15 PM
bikercouple
Mar 18, 2015 05:53 PM
harfooz
Sep 1, 2011 10:40 PM
pparker1213
Jun 13, 2010 03:13 PM
rcjoy2
General Topics/Tech Tips
Mar 2, 2008 08:07 AM
