momentary switch????????????
Old Feb 22, 2007 | 06:28 PM
ultraultra's Avatar
ultraultra
Default RE: momentary switch????????????
I posted this before, I bought the HD auxilary switch housing that mounts to the control (left or right). It holds 3 switches, I just used one of those, and it doesn't look odd.. it looks factory. Got a Genie garage door opener from Home Depot, and you are ready to go.
Old Feb 22, 2007 | 09:49 PM
BIGCHIEF's Avatar
BIGCHIEF
Went to the website of the "Autoswitch". For $30 it sure seems to be the answer to the garage door opener fix. I look forward to hearing how it goes.
Old Feb 23, 2007 | 09:05 AM
Bryan TTM's Avatar
Bryan TTM
3 bucks and mine works two of em
Old Feb 23, 2007 | 08:52 PM
relli's Avatar
relli
ORIGINAL: FLHT
I used a small momentary button switch I got at radio shack. drilled a hole in the middle of the switch blank next to the Aux switch and then bought the rubber button cover from the odometer switch to cover it. If you want I can snap a photo of it.
could you please? i was thinkin that EXACT thing but wondered bout the water. like the idea of the odometer switch cover. was at the dealer yesterday (great exp BTW) but "kid" on the counter didnt know anything and said ihad tobuy a two -three -or 4 button harness to get an oe switch.
Old Mar 16, 2007 | 01:31 AM
gabhart's Avatar
gabhart
ORIGINAL: BIGCHIEF
It went well! I have a Genie garage door opener and it happens to run on 12 VDC. I soldered 2 wires off thebutton inside a spare remote that I had. The Auto Switch connects to 12VDC along with the remote. Both are grounded and the Auto Switch gets it's trigger from the high beam wire that goes to theheadlight itself.
ALED is also included so you can tell if your garage door remote has been activated.I mounted the LED above and center of my speedometer and tach. It turns on red when the bike is powered up, it flashes green/red when you toggle the high beam switch and it goes solid green when the remote had been activated.
This is very easy and straight forward on an Ultra once you remove the outside fairing half. Every connection is done there and both the remote and Auto Switch are hidden there as well.
The remote/Auto Switch are together on top of the stereo next to the CB.
Here are a few photos:
Northride
2014-2024 Touring Models
Nov 18, 2017 10:17 AM
Rob98208
Sep 6, 2013 09:56 AM
KYBill
Jul 12, 2013 03:58 PM
brummie
Apr 2, 2012 08:29 PM
