rineharts
Old Mar 16, 2007 | 12:54 AM
jeff986301's Avatar
jeff986301
Default rineharts
i have an 07 srteet glide and wanna put rh t/d on it.my question is do i have to change anything else, controller or intake?
Old Mar 16, 2007 | 01:01 AM
ndotken's Avatar
ndotken
Default RE: rineharts
Yes and yes.
Old Mar 16, 2007 | 01:11 AM
jeff986301's Avatar
jeff986301
i've had someone tell me i can get away with just the intake change
Old Mar 16, 2007 | 01:14 AM
jeff986301's Avatar
jeff986301
someone told me i can just change the intake????
Old Mar 16, 2007 | 01:19 AM
tduff's Avatar
tduff
If you change the intake, you'll need to put on a fuel management system/device like a Power Commander PCIII or the H-D SERT so you're not running to lean.
Old Mar 16, 2007 | 01:34 AM
ndotken's Avatar
ndotken
tduff is right ... the '07's are set up lean at the factory to meet EPA regs. Adding a high flow AC or high flow pipes will only lean out the fuel mixture even more and make the engine run even hotter. It's possible that you could run too hot and damage the pistons or rings. You're going to need to enrichen the mixture, which requires a PCIII or SERT. Don't take the word of a service tech at the dealer ... call HD Customer Service and ask them.
Old Mar 16, 2007 | 01:39 AM
jeff986301's Avatar
jeff986301
thanx for the info
Old Mar 16, 2007 | 01:41 AM
jeff986301's Avatar
jeff986301
thanx for the info bud
Old Mar 16, 2007 | 01:59 AM
07 FLHX's Avatar
07 FLHX
I'm not going to say that you HAVE to do anything with just the True Duals, but I put on the K&N filter kit and the PCIII along with the Rineharts.......Runs great......Sounds awesome!!! You can get the filter kit along with the PCIII from Jamie at Fuel Moto for $400 delivered.
FinalShot
2014-2024 Touring Models
16
Mar 10, 2015 10:23 AM
Ribcracker
May 24, 2008 07:58 AM
dsmith7755
General Topics/Tech Tips
Feb 19, 2008 07:11 PM
IdaSpudSG
Jul 2, 2007 08:38 AM
