finding neutral
Old May 28, 2013 | 04:09 AM
  #51
ironhead3fan's Avatar
ironhead3fan
Easier to find from 1st gear, and yes, it did get easier once I changed the fluids to synthetic.
Old May 28, 2013 | 04:44 AM
  #52
jamesroadking's Avatar
jamesroadking
On my 2010 Limited 103 neutral is real easy to find. I have almost 20K miles on her now.
I think I might have a adjusted the clutch cable maybe once. Bikes never been back to a dealership. I do change the primary, like the engine oil every 3K miles. Maybe always keeping the primary oil fresh and clean helps, not only with longevity but with finding neutral.
Old May 28, 2013 | 04:59 AM
  #53
hapbob's Avatar
hapbob
Its a technique to find it sometimes...I find that while driving in the driveway in 2nd I get close to the garage and go to neutral and coast in..
Hap
Old May 28, 2013 | 05:56 AM
  #54
RK Joy's Avatar
RK Joy
Originally Posted by Keithhu
Its easier when you are rolling. If I need to be in neutral, I try to do it before I stop.
That's usually what i do as well.
Old May 28, 2013 | 06:33 AM
  #55
luisan's Avatar
luisan
I don't know if there's any correlation but since I changed to RedLine oils and had the Hayden tensioner installed finding N is not a problem anymore.
Old May 28, 2013 | 06:37 AM
  #56
Big Trev's Avatar
Big Trev
No, none what so ever
Old May 28, 2013 | 06:45 AM
  #57
Rick Lees's Avatar
Rick Lees
I got it down pretty quick its as easy as a quick little tap with the heal and its there........that is after you get first
Old May 28, 2013 | 09:06 AM
  #58
cubalz's Avatar
cubalz
You gotta blip the throttle and tap it into neutral. It is a pain otherwise...
Old May 28, 2013 | 10:56 AM
  #59
oricko's Avatar
oricko
I must be one of the lucky ones only had this problem once or twice. Use Amsoil in all 3 holes.
Old May 28, 2013 | 11:43 AM
  #60
danzio's Avatar
danzio
I didn't have the time to read through all the posts and maybe it's already been suggested, but I've found over the years, that keeping the primary just a little less than full really helps me. I generally fill it an ounce or two shy of the recommended amount.
