Noisy Tappets
What?
No....... It's 100% petrolium. Who "enlightened" you? Slap them, because they're wrong
Here's the MSDS
http://www.lucasoil.com/images/media...01-3-26-12.pdf
Here's the TDS
http://www.lucasoil.com/images/media...abilzr_1_2.pdf
Here's the MSDS
Here's the TDS
Put Lucas in a blender at low speed (much like the inside of an engine) and you get suds!
You use it if you like. I'll pass....
Seriously.... dude... did you try that? ..... BTW most fossil oils also foam up, unless they have anti-foaming additives. Pennzoil looks like freshly poured root beer it foams up so much.
1. I don't like using machinery with an issue until it breaks I believe in preventative maintenance.
2. I want to take a cross country trip and with my bike but in it's present mechanical condition I don't feel confident with it's current mechanical state.
This bike has only 5000 miles on it and I find it's current mechanical state as unacceptable. Oh the dealer did offer me a fix for the noise, they offered to sell me a set of headpipes, mufflers, airbox and tune to mask the noise.
And I still believe I would still hear the ticking even with a louder exhaust.
What a racket Harley and these dealers are running.
First, I live in San Antonio, Texas but, from what you have said, my opinion of whether your valve train is noisy or not is subjective so it doesn't matter. We could listen to your "new" bike and compare it to both of my "old" bikes; that might tell you something.
Bottom line is the motor is an air cooled 45*, pushrod/rocker arm, vtwin. There is metal to metal contact at, oh let's count them, cam lobe to lifter, lifter to pushrod, pushrod to rocker arm, rocker arm to valve stem and valve to valve seat; five metal to metal contact points. How in the heck can you expect that configuration to run quietly??
Don't expect the dealer to solve the problem. If you want to go down the rabbit hole of chasing valve train noise, you will have to do it on your own. There are plenty of guys on this forum and others that can tell you where to look. In your situation, I would try two things:
1. Run a straight weight oil, say 50W or 60W.
2. If that doesn't help, consider changing the lifters; the lifters in the later models have been made in Mexico since the 2010 model year and there have been issue with the rollers. A set of CompCams VThunder lifters would run about $60, plus gaskets and a couple of hours to make the change.
Lastly I would say that if you don't have the confidence to take a cross country trip on that bike, get rid of it and get yourself a Honda; they are quiet and never have any problems.
...Bottom line is the motor is an air cooled 45*, pushrod/rocker arm, vtwin. There is metal to metal contact at, oh let's count them, cam lobe to lifter, lifter to pushrod, pushrod to rocker arm, rocker arm to valve stem and valve to valve seat; five metal to metal contact points. How in the heck can you expect that configuration to run quietly??
