Hard Clutch/ Barrnet cable
Old May 19, 2013 | 03:06 PM
HDJIM1158's Avatar
HDJIM1158
Default Hard Clutch/ Barrnet cable
I switch my bars a few months back. I also switched the clutch cable to a barrnet plus 8. I correctly adjusted it and have been riding the bike for a few months. The clutch level was a little harder to pull then stock but it didn't bother me. Up at Myrtle Beach, my friend took a ride and came back saying something is wrong, the lever is much too hard, after riding his, I see what he means. Is this normal ?? The cable was lubed, do u think it needs more ?? I am going to pull the batwing to see if its bent around something. Any thoughts ???
Old May 19, 2013 | 03:35 PM
cruzmisl's Avatar
cruzmisl
I can't help but can say I've had a Barnett cable on my old bike and it performed flawlessly. No increase in lever pull. Something must be binding the cable.
Old May 19, 2013 | 03:38 PM
Stiggy's Avatar
Stiggy
Check everything including the 3 ball ramp under the clutch actuation cover on the right hand side.
Possible throwout bearing?
Good Luck
Old May 19, 2013 | 03:48 PM
HDJIM1158's Avatar
HDJIM1158
Angry
Good Luck
Great, got to pull the pipes off to get the the trans cover....... Damn !!!
Old May 19, 2013 | 05:22 PM
gbear's Avatar
gbear
no need to pull the pipes, remove your heat shields and use ball head allen wrenches to get the job done. I have changed three clutch cables out on three different bikes and have not removed pipes yet. good luck.
Old May 19, 2013 | 06:06 PM
HDJIM1158's Avatar
HDJIM1158
I wish, I have the V&H X Pipe
bjchaffin2
Jun 17, 2024 07:28 AM
deez nuts
Apr 23, 2017 10:48 PM
rmtwrx
May 9, 2016 06:28 AM
jamieg101
Apr 12, 2012 12:17 AM
cwsharp
Apr 21, 2008 06:18 AM
