NO ideal....
Old May 20, 2013 | 10:54 AM
Braveheart1222's Avatar
Braveheart1222
Default NO ideal....
2013 road glide ultra and lighter does NOT work... Checked fuse=intact, reverse the plugs in the fairing= no change.. Not sure its the lighter itself or wiring... Note: lighter didn't work since day one....so, I figure it was wired wrong and when I change my bars and switch the plugs the result is still the same...
1.) maybe try a different lighter
2.) return to dealer and let them sort it out...
Side question.... I have Nothing to my knowledge plug into the accessory switch, should the accessory light still come on when button is pressed with nothing attach?
Old May 20, 2013 | 10:56 AM
47909Rider's Avatar
47909Rider
Dude, if it's a 2013, why are you even bothering to go through all this trouble? Your dealer has to take care of it; it's definitely under warranty... O_o
Old May 20, 2013 | 11:01 AM
Braveheart1222
Agreed.. the goal is not to have my bike held hostage for 2 weeks... thanks....
Old May 20, 2013 | 11:02 AM
RollaMo's Avatar
RollaMo
Since you didn't mention, I'll ask a stupid question.
Did you have the ignition switched on (or on ACC) when trying?
There is no current going to that plug with the ignition off.
Old May 20, 2013 | 11:04 AM
mkguitar's Avatar
mkguitar
you could always try a test light or a voltmeter.
got a wiring diagram?
Mike
Old May 20, 2013 | 12:05 PM
grbrown's Avatar
grbrown
No brainer!
Old May 20, 2013 | 12:19 PM
PistonPuller's Avatar
PistonPuller
Warranty? And I doubt it would take 2 weeks.
Old May 20, 2013 | 12:23 PM
Braveheart1222
tried it both ways....
Old May 20, 2013 | 12:26 PM
Sam2010's Avatar
Sam2010
The light will come on switch when switch is on no problem there. Take bike in for lighter.... Should of addressed it day one on the spot.
Old May 20, 2013 | 12:30 PM
Braveheart1222
Thanks.. for all the response.... I will be taking it to the dealer this weekend...
