Starter Issues.
Old May 22, 2013 | 08:27 PM
Drac 1's Avatar
Drac 1
Default Starter Issues.
It started in the garage this am with no problem. Rode to the gas station and filled it up and it restarted. Rode for about an hour, stopped 6 doors from my house to chat with another longtime Harley rider.
After about 15 minutes I attempted to start it and nothing. We pushed it home and after it cooled down I checked all the wires, connections and battery terminals, all looked fine. Tried to start it again, it would crank once and then it gave that annoying chatter sound.
That means a low battery right??
Old May 22, 2013 | 08:29 PM
kel03's Avatar
kel03
That would be my vote for starting point !
Old May 22, 2013 | 08:30 PM
mkguitar's Avatar
mkguitar
chattering solenoid means that it is not getting proper current. ( or less likely that the solenoid is pooched)
and to allow it to chatter will damage the solenoid in time...so don't.
charge battery fully with a battery charger ( not a tender) and have load tested.
if it is good, then reinstall and we'll see if your charging system is failing...
we always check with a known fully charged battery and good cables/connections...other wise money can be wasted and tails chased
so battery and cables first, then we can look at the solenoid and starter and starter drive...or the alternator ( stator) and regulator
if it turns out you need a new battery there was a thread today on a $99 deka battery...deal!
Mike
Old May 23, 2013 | 01:37 PM
Drac 1's Avatar
Drac 1
Thanks guys. It was the battery, got too low to hold a charge. Old one removed and cable ends cleaned. New one installed.
Rusty Axle
Shovelhead
Apr 18, 2020 07:20 AM
Nitro Joe
Electrical/Lighting/Alarm
May 4, 2018 04:25 AM
wideglideCVO
Jul 12, 2016 10:54 AM
cowpoke
Engine Mechanical Topics
May 14, 2014 08:19 AM
Asuperglide
EVO
Sep 15, 2011 07:53 PM
